can i tie in a CM cage with mild steel SFC's?
Old Feb 5, 2005 | 05:01 PM
FireRed91Z28's Avatar
Car: 91 Z28
Engine: currently 350...BUILT 383 soon
Transmission: T56 w/4.10's
like the title says...can i tie in a Moly 10 pt roll cage with mild steel sub frame connectors? would it be better to cut out the old MS SFC's and replace with CM ones?
Old Feb 5, 2005 | 06:28 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
I was wanting to do 4130 cm subframe connectors and Steve Spohn advised me that to properly install them, I would need to have them tig welded since my car is made of regular steel.
I would assume that your situation would be the same.
However, I've heard that during WWII cm was used in some aircraft and that one of the other methods of welding were used for that, but I don't remember which.
Old Feb 6, 2005 | 10:36 AM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
Re: can i tie in a CM cage with mild steel SFC's?
Absolutely. TIG is the only method allowed by the sanctioning bodies for welding CM. Use a mild steel rod - I prefer ER70S-2. No post heat-treating required. I'd keep the MS subframe connectors. It'll be a real pain to cut them out, and there is little to be gained (weight wise) by replacing them with CM steel ones. FWIW, I have a full MS 2x3 frame in my car with a full CM cage.
Ed1LE
Sep 30, 2018 09:14 AM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
FueledSoul
Sep 30, 2015 09:18 PM
tmork454
Sep 29, 2015 06:33 PM
