Stock Height?
Old Feb 13, 2005 | 03:26 PM
Rons91Bird's Avatar
Car: 1990 GTA, 75' Formula 400
Engine: 305 TPI, BB400
Transmission: Automatics in Both.
Axle/Gears: 2.73 in the GTA, soon to be 3.42
Stock Height?
Hey everyone.
I have been in the process of re-building my chassis for the past month.
Alston sfc, all new steering components w/ Edlebrock Tie rod sleeves, swapped stock sway bars to 36mm front & 24mm rear, new poly bushings all around, Wonderbar, and have a quick ratio steering box from an Iroc not yet installed!
I want to replace the Panhard bar & Lca's next. How can you tell if the car has been lowered? I don't think it has been, as it carried all stock components ( panhard bar)
I do not want to lower it! As i beleive these baby's sit low enough allready IMO!
Thanks All, Ron
Old Feb 15, 2005 | 05:32 AM
Rons91Bird's Avatar
Cmon Guys, anybody out there?
Old Feb 17, 2005 | 01:15 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Are there factory tags on your springs like BZX, etc? What color are the springs that you have?
Even if your springs are stock you may have a lowered suspension because the springs are worn.
How much of a gap do you have from the tire to the wheel lip? On the later model F-bodys it should be about two finger widths.
Old Feb 17, 2005 | 11:03 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
You must have really big fingers. Stock height for 3rd gens were very high when brand new. People don't realize that today, all they see are cars with 15 year old springs. Gap on the front tire to fender was about 3" stock (4 fingers).
Old Feb 17, 2005 | 02:44 PM
Jade Grey's Avatar
Engine: 305TPI
Sorry, it's that I should not post after 2 AM. I meant to say about four fingers wide. Mine stock is closer to almost five fingers or about 3.5".
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Genopsyde
Oct 7, 2015 08:35 PM
sailtexas186548
Aug 26, 2015 03:32 PM
