Raise The Rear
Old Feb 13, 2005 | 10:48 PM
deltahunters's Avatar
Car: 1986 Trans Am
Engine: 305 cid
Transmission: 4 sp auto
Raise The Rear
Does anyone have any ideas on how i can raise my rear end on my 86 trans am to give it an "oldschool" look. like jacked p in the rear any info is much appreciated.
Old Feb 14, 2005 | 12:19 AM
onebinky's Avatar
If you want to do it the oldschool way, use airbags. It just doesn't look right on a thirdgen though
Old Feb 14, 2005 | 08:37 AM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Don't forget the mudflaps with the chrome nake chic on them, the rear window louvers, and a 10 ft long CB antenna to complete the look.
If you're going to do it, go all the way!
Old Feb 14, 2005 | 08:39 AM
Guido's Avatar
Car: 2000 Trans Am
Also, dont forget to add the 1" true duEl exhaust on it so when it runs 17.85 @ 81mph in the 1/4 at least it will SOUND fast.
Oh yeah, and a hood scoop for it.
Old Feb 14, 2005 | 09:17 AM
Bill87GN's Avatar
Dude, if you do that you're going to need a 3/4 race cam to back up that look.
To to lift up the rear, the easiest way is to cut some 2x4s on block and place them in between the spring coils.
Now you'll be jacked up like a motha!
Old Feb 14, 2005 | 09:40 AM
ede's Avatar
ede
old school method fro all your youngsters that missed it when it was the thing to do would be to use air shocks, not air bags, along with a set of slapper bars.
Old Feb 14, 2005 | 09:47 AM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
Also if yo do this you need to get one of those Hats with the built in MUL_LETT(apararently a banned word)..Thats a must...
Also dont add normal dual 1" exhaust... Instead you need dual 1" sidepipes...
finally to complete the look I suggest stopping by the local carry-out and picking up some Skoal and some PRB..
Old Feb 14, 2005 | 10:44 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
since everybody else is being so helpful. the easiet way would be go the gm dealer, and ask for spring isolators, make sure theyre for 93+, then just lower the rear, pop the old ones out, put the new ones in. should raise about an inch if thats what you want to do
Old Feb 14, 2005 | 01:22 PM
kevinc's Avatar
Car: 1982 Z28
Grab a pair of Hypercoil single-pigtail springs, 275# 12" free height should do the trick.
http://www.daymotorsports.com/product/1058/v/43/
BADNBLK
Nov 16, 2016 09:12 AM
toronto formula
Nov 10, 2015 06:17 AM
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
69 Six Pack
Oct 5, 2015 07:51 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
