manual s10 steering box
Old Feb 25, 2005 | 10:25 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
Axle/Gears: ford 9in 4:56 to 1
is a manual s10 steering box a bolt on or do I have to modify anything?
Old Feb 25, 2005 | 11:17 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
9 times out of 10 they will bolt in unless you got an 82-84 s10 box. ive heard the rag joint was different.
it bolts right on where the other box came off, you just have to reuse the camaro pitman arm on the s10 box.
only do this if you are a drag racer/street cruising.
this will be your worst mod ever if you like to carve corners.
good luck.
1992 Trans Am
May 10, 2023 07:19 PM
Amillionoh7
May 24, 2020 08:01 AM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
zayne0
Aug 24, 2015 07:22 PM
