Whats the biggest tire i can stick on my 92 RS?
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
i just have the stock 15X7 rims (i believe thats what they are) and i was wondering what the biggest size tire i can stick on them would be, right now i have 215/65/15s.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i've got 275/60/15's on my stock 15x7 rims
some will say that's too big, but i have neve had any issues.
they are 28" tall by 9" wide, i've only got the on the rear.
Car: 83 Z28
Engine: 400
Transmission: Th 350
Axle/Gears: 3.27 9 bolt
I had 265/50/15 on mine worked great all the way around stuck to the road well and overall height was close to stock kept speedo close
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
thankx guys, as for height if i need i can get some of these spring spacers that raise the back end up like 1" from stock. i guess my question really is, how big can i go and not have clearance issues if i DID the spring spacer and then if i DIDN'T do the spring spacer. thankx again for your help
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
and for tire rotation my rear tires don't last long enough to be rotated. i have cooper cobra's on my car right now and would they be able to get me the size i needed to if i asked? and the biggest size so far i've been told is 275/60/15, if i did the spring spacer how much taller could i go with the 1" spacer? i'll deal with the speedo later when i can figure out which speedo gear i need to install.
2MNYMaros
Sep 15, 2015 11:36 PM
