will lowering springs work with gas shocks?
Old Mar 9, 2005 | 08:52 PM
davcamaro's Avatar
Car: 1985 IROC
That's about it. I had gas shocks (also called air shocks) on the back of my car around a year ago and I am looking into getting the eibach pro spring kit and I want to know if I will have to change these shocks out or if I can stay with them. I am also looking into what kind of struts I should put in the front if I switch the springs out. thanks
Old Mar 11, 2005 | 07:53 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Are you talking about air-adjustable shocks or shocks that are filled with a gas as opposed to oil?
The Eibach Pro Kit is a physically shorter spring. There's no reason that it will not work that I can see.
If you are on a budget but still want decent aftermarket struts/shocks, look to the KYB's.
If your budget is bigger go with Tokico, Koni, or Bilstein.
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
sailtexas186548
Aug 26, 2015 03:32 PM
AkDrifted
Aug 17, 2015 07:45 PM
