Is a 2wd S10 a-arm the same as ours?
Old Mar 13, 2005 | 09:48 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
I know the spindle stops are probably different, but aside from that, physically, do they interchange and keep the same geometry?
Old Mar 14, 2005 | 06:38 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I'm not real sure; but ours are DEFINITELY also used on some kind of upper/lower arm vehicle, because they have a shock absorber mount in them. It would be good to know which one. Could be S truck or A/G body car.
Old Mar 14, 2005 | 01:05 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
i know theyre exactly the same as they are one both of my dads '78 cutlass', so g-body is def
Old Mar 14, 2005 | 07:48 PM
DSM's Avatar
DSM
Car: 84 Z28
Axle/Gears: 3.73 Torsen
the lower control arms on 78-87 G-body, 82-up S-10 and 3rd gen F-bodys will physically interchange. There are some differences however - 1) The outside diameter of the control arm bushings can vary, so if you need to order replacement parts based on the original application 2) the steering stop which is riveted to the back side of the control arm is different depending on the application. This can either cause the tires to rub at full lock or limit the steering travel, depending on which arms you have and what you are putting them on.
Old Mar 14, 2005 | 08:08 PM
drain89's Avatar
Thanks man!
Old Mar 14, 2005 | 09:51 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
yup, i'm using 90s S10 a-arms.
Old Mar 14, 2005 | 10:20 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
So 2" drop bucket a-arms for an s10 should fit right in?
Old Mar 16, 2005 | 10:53 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
If they do, then it will make alot of people happy.
Old Mar 16, 2005 | 12:30 PM
Dale's Avatar
Engine: 350 S-TPI
I looked, only 3" drop
289 a set
Old Mar 16, 2005 | 03:39 PM
83 Crossfire TA's Avatar
Dropped spring seat control arms won’t do you any good on a 3rd gen, unless the actual frame work of the A-arm is bent downward right by the control arm bushing. The back side of the control arm will contact the K-member if you try to go much lower then what they typically available drop springs allow for.
Even if it is bent down to clear, there isn’t that much room before it would become an issue if you had a flat tire.
Ed1LE
Sep 30, 2018 09:14 AM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
92projectcamaro
Sep 24, 2015 08:09 AM
buckshot63
Sep 10, 2015 09:15 AM
