TIREStiresTIREStires?????
Old Mar 22, 2005 | 10:02 PM
Sidewayz28's Avatar
Car: 2001 Camaro SS
okkk.....for my birthday, which is in may, im asking my parents to get me tires! right now i have 255/50/ZR16's Kuhmo Ecsta tires. for one, the tires are going out and two, i have no traction in the rain :-\ and seattle is a place you need SOME traction in the rain! what are YOUR suggestions on a sick *** tire, with some major dry traction and a decent wet traction meant for the STREET? i was looking at the BFG t/a tires that have that crazy tread design...... but please give me some suggestions!!!! thank you!
Old Mar 22, 2005 | 10:35 PM
Dynodan's Avatar
Car: 1992 firebird
Engine: 305tbi
I like the bfg for stickyness , didn't like them for how many times that got holes in them from foreign objects. I had the kumho's also , I hated those had the same problem you have, no traction what so ever in rain. They also weared out uneven. I am running cooper gt's now . I like em but only had em on for 3 weeks so the jurys still out on them.
You might want to ask the tire dealer ship for ratings on the softness and rain hookup.
Dynodan
Old Mar 22, 2005 | 10:49 PM
Sidewayz28's Avatar
Car: 2001 Camaro SS
thank you for your advice, yes my kuhmos must be a few years old, i have to drive granny style in the rain or im going sideways
Old Mar 22, 2005 | 11:08 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
My next tires will be Yokohama AVS ES 100's. I have the Dunlop 5000's now and they are ok. I want to try something else.
Old Mar 23, 2005 | 01:08 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I'm having good luck with my nitto nt 450's around here. Although I haven't used too many different types yet. Plus they were cheaper than the kumho's.
Old Mar 23, 2005 | 01:36 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I am running Nitto 555RII race tires and they seem to be pretty decent in the rain.
they are awesome on dry surfaces but have a very low tread wear rating, 100. most tires are 180-330.
The BFG T/A KDW old style tread does great in dry and wet weather, I'd recommend those. I have no experience with the new tread design.
Old Mar 23, 2005 | 03:07 AM
CrazyHawaiian's Avatar
Car: too many ...
I've always liked Bridgestone Potenza's. They have some awesome technology behind their tires, and the stuff works good (from my experience). I'm running their S03's on another set of wheels and they handle awesome in the dry and wet. Probably the best tire I've ever owned, and I do go through quite a bit of tires (from drifting). The thing I like the best about the S03's is that they still grip great when they are worn down. Other tires I've had grip good, but when they wear down a bit they dont grip as good. Not so with the S03's, they will be just as good the day you trash them that they were the day you bought them.
But they dont make the correct tire size in S03's for the 16x8's. Its either 225/50/16 or 245/45/16. If you dont mind having a smaller sidewall, I would opt for the 245/45/16 S03's. When I was getting tires for my 16's, I wanted to retain the OEM sizes, so I didnt go with the S03's. I went with a lower model of Potenza, the RE730's in size 245/50/16. Those RE730's handle good in the rain too, better than any other tire I've had on my 16's (Kuhmo 712's, Yoko AVS100's, and of course the lower quality tires like Eagle GT II's or whatever). But they werent as good as the S03's (didnt use the same technology). The RE730's have since then been replaced with the RE750's, probably just as good of a tire. The next step up would be the new RE950, and that RE950 uses alot of the same technology of the S03's and comes in a 245/50/16 size. So thats the tire I would recommend for you if you want great wet/dry handling and OEM size tires: Potenza RE950 in 245/50/16. Next set of tires I buy for the 16's will definately be those.
Old Mar 23, 2005 | 11:11 PM
Sidewayz28's Avatar
Car: 2001 Camaro SS
yah i was also curious abuot those Nitto tires, ive seen some in a couple of magazines and they look pretty nice...
oh and getting aluminum dipped rims? how much would that cost...just an estimate?
Old Mar 23, 2005 | 11:31 PM
5.0Camaro's Avatar
Car: 1991 camaro Z28
BFG KDW are great tires for rain/dry, but neither do i have experience with the new tread design since they didnt have it for a 275/40/17 tire but they might have it for your size. Tirerack.com says they are better then the older design.
Justin
Old Mar 24, 2005 | 11:03 AM
IROCBlueZ28's Avatar
I used to have the PSO2's on my vett. And if the so3's are a newer tire, which they are, are sure to be awsome! My S02's were incredible! Super sticky on the dry and wet! I could not agree more!
Old Mar 24, 2005 | 04:20 PM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
Check out www.thetirerack.com , they have tire reviews and data
for tires
Old Mar 24, 2005 | 06:42 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
Potenza, Is the best wet tire I have ever had. Period.
It also was better in the dry than Goodyear Gatorbacks and GSC
Old Mar 24, 2005 | 08:45 PM
Sidewayz28's Avatar
Car: 2001 Camaro SS
i like how those s02s look, i would rather have extremely good traction on dry and ok traction on wet
Old Mar 24, 2005 | 11:58 PM
Which model of the potenza? I think they are tire second to the so2 so3's? All I remember is that my corvette hooked up awsom with the PSO2's! I had BFG's comp ta's on the vet prior and the wet traction was far superior with the Bridgestone PSO2's and the Dry was just as superior as compared to the BFG's. night and day! One thing I did notice with my comp TA's was that the more wear i got on them, the less they preformed on wet. Later towards the end of thier life, dry has been really bad too. Reading the reviews on teh bridgstones, they hold their wet traction after many miles, dry too?
Currently, I have BFG's on the back of my Z since 99 and need some new rubber. On the front I have the nitto 450's. I was planing on running the nitto 555 drag radials in the rear, but I dont want them due to low life. SO, How do the new BFG's KWD compare to the Potenza's? From my experience with the SO2's, I would easily be moved to a potenza from the BFG's if the traction of the potenza is better than the new BFG's KWD's especially in the dry. ALSO, which potenza? the 750 or the 950?
Old Mar 25, 2005 | 01:10 AM
SDIF's Avatar
I forget the flavor, but they are no longer made. I tried to get the same tires again, but tire wreck said they were now improved.
I guess the new model would be even better.
Old Mar 25, 2005 | 01:18 AM
which did you have??????
Old Mar 26, 2005 | 06:35 PM
laiky's Avatar
i'm hearing good things about infuzions, a new brand from bridgestone. About 80 bucks from tire rack. Thinking about these myself.
Old Mar 26, 2005 | 08:29 PM
A10Beav's Avatar
Engine: LS2
Axle/Gears: Moser Ford-9, 3.50
If you drive in the rain a lot, you should look at the Goodyear GSD3's. It's a European tread design (ie, aggressive wet tread design) and it's pretty sticky on dry roads too. Straight line acceleration isn't as good as BFG's or Nitto's, but they take turns pretty well.
If you want an affordable tire, look at BFG Traction's. I have them on my daily driver and I'm pleased with them. Not high performance tires but they grip pretty well, are directional for water dispersion, and they have a 60K mile warranty.
Check local stores or on-line for prices.
Old Mar 26, 2005 | 11:45 PM
I was really impressed with the bridgstone's PSO2's and heard great things about the 750's too. I think I am going with Bridgestones this summer, which ones, I don't know....potenza 750's i guess.
The thing that impressed me about my pso2's was the traction was still there towards the end of the tire's life! Unlike my BFG's. They are at the end of thier life and they are slick!! Definatley getting the bridgestone's, just gotta figure out which ones. I hope I can still get the potenza 750s.
Old Apr 22, 2005 | 03:46 AM
Cam91z's Avatar
Car: 91 Z28
Engine: 305TPI
Transmission: 5 speed
Dont get a fuzion there to hard. Ponteza is the way to go. The new entry level Potenza Goo9 is a exellent tire. I have them on the rear, 2455016, got em both for 150. Thats cause i work for them. They get excellent traction, before i got them first gear would be mostly spinning. With these tires that has stopped, they just grip.
Old Apr 22, 2005 | 09:43 AM
I'm hoping to get a bridgstone such as the potenza re750 which are in the same class as the bfg's comp ta's, just better due to the uniT tech.
Old Apr 25, 2005 | 12:08 AM
Sidewayz28's Avatar
Car: 2001 Camaro SS
how about some Eagle F-1's?
Old Apr 25, 2005 | 07:10 PM
Cam91z's Avatar
Car: 91 Z28
Engine: 305TPI
Goodyear is a harder tire than a Bridgestone. And they cost more.
Old Apr 25, 2005 | 08:38 PM
Abubaca's Avatar
I've run just about all different brands and without a doubt, the potenza's and the Bfg's were best. Right now I have the BFG KDWS and I love 'em. The potenza's I had were the RE910, which are no longer available. I imagine all there products are pretty good.
Both of those tires (BFGs and Potenzas) were all season tires. For lots of rainy use, that's the only way to go. They're made that way for a reason.
Old Apr 26, 2005 | 10:05 AM
i had the older style bfg's and my PSO2's were so much better new and at the end of their life! I was reallly, REALLY impressed with the pso2's! I"m gonig bridgestone's again!
Old Apr 27, 2005 | 07:07 AM
A10Beav's Avatar
Engine: LS2
What kind of tread life do these PS02's have?
Old Apr 27, 2005 | 10:54 PM
Cam91z's Avatar
Car: 91 Z28
Engine: 305TPI
PSO2 DONT HAVE A SET RATING CAUSE ITS A HIGH PERFOMANCE TIRE. BUT PROLLY AROUND 30.
