What Rims??
Old Mar 27, 2005 | 05:42 PM
Yossarian14's Avatar
Car: 1986 z28 and 1997 Disco
Engine: Lg4 305
What Rims??
I was going to user a spacer but the owner of the tire rack told me that was a bad idea. Then, my stock wheels dont look so good so I am trying to figure out what aftermarket rims fit stock on my car (86 z28). Could someone just list as many wheels as they can that dont require anything like spacers? Any info in great, thanks.
Old Mar 28, 2005 | 12:49 PM
Engine: Lg4 305
Come on, please anyone?
Old Mar 28, 2005 | 01:27 PM
l98+t5's Avatar
Car: 1988 camaro iroc-z z-28
Engine: L98 5.7 liter 350
Transmission: T-5 manual 5-speed
hate to say this but do a search i know everyone says this but honestly just take some time tyo look at sites and threads. TT2's firehwaks, later iroc's, i know how ya feel though everyone wants new rims
Old Mar 28, 2005 | 05:54 PM
Engine: Lg4 305
Well I was on the Hawks site and they said that they make Zr1's thats fit without and spacer, etc and I was just trying to fig out if this was true really.
Old Mar 28, 2005 | 10:34 PM
A10Beav's Avatar
Engine: LS2
Axle/Gears: Moser Ford-9, 3.50
Just search as many wheel websites as you can find, look at the wheels you like and then look at the specs. You need a 5 on 4.75 inch lug pattern (120.65mm), and a 0 to +6 offset for a stock fit. You can use spacers, but I wouldn't use them on the rear if you have a lot of torque.
It can be a frustrating search, but it's your car so it's worth the time.
Old Mar 28, 2005 | 10:40 PM
Engine: Lg4 305
0-6 for the offset you say? So does that mean that 3 looks the best?
Old Mar 28, 2005 | 10:44 PM
A10Beav's Avatar
Engine: LS2
That will work. Most wheels now have a +30 to +45 offset, so they will all require spacers. I'll tell you it's tough finding wheels with our offsets, but they're out there.
Old Mar 30, 2005 | 08:38 AM
Jschoepf's Avatar
Car: 1986 Trans Am
Engine: 6.0L LQ4
If you go with a wider rim (like say **x10),on the back, where you did have a 15x7, would you need to have a different backspacing so that the tire doesn't stick out past the edge of the car?
[edit] Another question, what do you guys think an appropriate backspacing would be for a tire this size? and also what would be the appropriate backspacing for a **x8 [edit]
Old Mar 30, 2005 | 03:35 PM
irocdan's Avatar
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
rims
here is mine with zr1's
Old Mar 30, 2005 | 03:36 PM
irocdan's Avatar
Car: 88 Iroc vert
rims
and here it is with zo6's and you wont use spacers,you will use adapters
Old Mar 30, 2005 | 04:31 PM
Engine: Lg4 305
Whats the difference between spacers and adaptors? Hawks said that the Zr1's will fit a Camaro without any of those I thought so how does that work. It says "These 17 x 8" ZR-1-style wheels were specifically designed to fit 1982-1992 F-Bodies without spacers or other modifications." So how about theese wheels for my 86z? http://www.hawksthirdgenparts.com/in...?v=1&pid=13964
Old Mar 31, 2005 | 10:58 AM
irocdan's Avatar
Car: 88 Iroc vert
spacers are like a big washer thats thick to take up the space difference needed to fill the gap.adapters do the same and have the new studs in them and they get bolted to your hub by its own studs. goto www.wheeladapters.com
Old Mar 31, 2005 | 02:27 PM
Engine: Lg4 305
Well thats what I assumed but I still cant understand why I would need to use spacers or adapters with the Zr1's I have in the link above. It says they fit without any modifications to third gen Camaros and they are only 17 by 8.
Old Mar 31, 2005 | 03:31 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Due to high demand, the wheels you have linked recently were released with 3rd gen specs. If you go with a set tailored for vettes and or 4th gens you will need adapters. Many go that route so that they can go much wider than 8".
Old Apr 6, 2005 | 12:50 PM
shawnc16's Avatar
Car: 86 IROC, 89 GTA
Engine: 350 blocks, both of em
Transmission: 700r4s
Axle/Gears: 10 bolt and 9 bolt, 3.73, 3.23
bolt pattern 5 by 4.75
17 by 8 fronts with 4 inch bs
17 by 9 1/2 5.5 in bs
thats what im runnin on my torque thrust IIs
Summit has em!
Old Apr 13, 2005 | 03:17 AM
quaker's Avatar
Car: '84 Trans Am
the zr1s for the third gens will fit as advertized. we got ours from slp
Old Apr 13, 2005 | 05:06 PM
irocdan's Avatar
Car: 88 Iroc vert
ss wheels arent 17x11 rears they are 17x9.5 all around
Old Apr 13, 2005 | 05:15 PM
johnjm22's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: WC T-5
ROH Snypers are a direct bolt on, there relativley cheap, and they look awsome.
Here's my car with 17x8's in the front and 17x9's in the rear.
Old May 18, 2005 | 01:08 AM
Donny's Avatar
Car: 85 Trans Am
Does anyone have these rims?
I am looking at getting a new set of rims but no one here has seen them. I found them on the internet but don't want to buy them & find out i don't like them on. here's the link to centerline galaxy
http://www.centerlinewheels.com/whee..._id=2&sw_id=15
I was wondering if someone has those rims if they can email me a pic of them on so i can see how they look before i buy them. there is no returning them after i buy them.
getting 17 x 9.5 with bfg kdw 275\40\17
17 x 8 with bfg kdw 245\45\17
if anyone has them email at yewyew@mts.net
thanks
Attached Thumbnails What Rims??-901_galaxy-20-5-lug
Old May 18, 2005 | 07:55 AM
91redTA's Avatar
Car: 91redTA
Donny
If you click on the sponsor above (G&T Fibreglass) and go view the customer rides, scroll down to a black TA. It has those rims on, although I think they look like 16s. Hope that helps you decide.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
kitt23
Exterior Parts for Sale
Nov 28, 2015 06:26 PM
dbrochard
Oct 10, 2015 01:03 PM
dbrochard
Oct 10, 2015 01:02 PM
