Wanted: pics - stock suspens, handling understand components
Car: Custom 1992 Camaro Z28 25th Anniver
Engine: 5.7L V8 350 L98 TPI
Does anyone here with a 3rd gen Camaro have an underside picture of their car (Stock) (muffler doesn't matter).
I'm looking for a picture of the underside rear (back half) from before rear wheels to the end of muffler?
Basically I want to see the stock suspension, sway bar, etc under the 3rd gen Camaro. (a 1990 - 1992 if possible)
Here is an example of what I am looking for : http://www.speartech.com/company_pro...exhaust6_a.jpg
Only problem is the picture is (1) too small, (2) has aftermarket parts (RED). I want to find the same pic with the (showing those components) that is completely STOCK and a CLOSER up view.. and a larger picture so you can make out what you are looking at ;-)
Thanks very much.
Thanks very much.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Do you need help identifying whether of not you have stock parts? Factory parts are easily identified by their stamped U-shaped design. Swap bars and springs are just plane black as well as bushings and end links.
NBrehm
Aug 25, 2015 11:49 PM
NinjaNife
Aug 23, 2015 11:49 AM
Linson
Aug 21, 2015 02:12 PM
