how adjustable are the Spohn front coilovers?
Old Apr 1, 2005 | 12:40 AM
C Murda's Avatar
Car: 91 Z
Engine: Somethin Nice!!
any one know? i currently have 2" drop springs and i love my stance. how many inches are these coilovers adjustable upward and downward? could i get the ride height with these coil overs that im at now (2" lower than stock) with my drop springs? im also in for autocross set up so i need very firm suspension.
Old Apr 2, 2005 | 05:10 PM
C Murda's Avatar
Car: 91 Z
anyone?
Old Apr 3, 2005 | 07:10 PM
84camaro400's Avatar
Car: 1984 Z28 T-tops
Engine: 406 Small Block
Axle/Gears: 3.73 9 bolt
coil overs
i have just got the coil over kit and installed it, i however do not have the car on all four tires yet but the papers that come with them say they allow you to drop the car 1 inch lower than stock it comes with 10 inch springs however you can get 8 inch springs and that will allow you to drop it further however they do not reccomend it. hope that helps
Old Apr 3, 2005 | 07:14 PM
C Murda's Avatar
Car: 91 Z
any idea on why they dont recommend it? i really want that spohn coilover kit but i also want to keep my current stance.
Old Apr 10, 2005 | 08:34 PM
it just says because of bind thats all it says sry i could not help you more
Old Apr 10, 2005 | 10:49 PM
Kandied91z's Avatar
depends on your choice of spring... your ride quality and adjustment all comes down to the spring choice. strut too of course but the adjustment is all in the spring.
Old Apr 11, 2005 | 12:16 AM
VILeninDM's Avatar
I don't know if you considered drop spindles, but you may want to check out this thread.
They'll drop the front 2 inches without affecting your springs or your suspension. I got lucky and found a used set of these spindles
Old Apr 11, 2005 | 04:59 PM
C Murda's Avatar
Car: 91 Z
ive considered the drop spindles but i am also in process of buying Baer Extreme+ front disks and they com with their own replacement spindles. im not sure if id be able to use drop spindles with this brake system? ive also email Steve Spohn about his front coilovers and he said they are currently working on a 2nd kit that "will literally let you set your k member on the ground". so hopefully this kit comes out soon cause i really want to do my front suspension all at once. i hope this new kit wont require the use of drop spindles, cause ive spent so much on my front brakes and dont want to encounter any problems....
Old Apr 11, 2005 | 07:32 PM
Kandied91z's Avatar
you would have to send the drop spindles in to baer for them to modify them which costs extra. unless you are racing and can use the fine tunning most drop springs are fine. the coilovers are a nice change and welcome some adjustment but it will take some work to find the right spring rate to make you happy and even then the ride is comparable to a drop spring at best. if your looking for adjustment/fine tunning for racing they are excellent otherwise many will be disappointed.
Old Apr 12, 2005 | 12:22 AM
VILeninDM's Avatar
are you sure the spindles you are getting from baer don't already have 2" drop? Few guys in that spindle thread mentioned that Baer had a "track kit" and they were supplying their own 2" drop spindles. They were curious who was Baer's supplier.
Old Apr 12, 2005 | 12:26 AM
C Murda's Avatar
Car: 91 Z
im not positive yet as i havnt recieved them but they mention nothing of it on the Thunder Racing site??
Frozer!!!
Jan 19, 2024 04:55 PM
NORTz89
May 20, 2020 03:51 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
zayne0
Aug 24, 2015 07:22 PM
