help with panrod
Car: 86 z-28
help with panrod
my panrod has a liitle bend in it is that why my rearend is pushed over a couple inches and my car sits lower on one side. what do i need 2 do 2 fix it when i put anew one on thanks guys
Engine: 4++,350 & 305 CIs
most of the 3rd gens I've ever seen sit a little higher on the pass rear.
Car: 1985 2.8L V6 Camaro
Engine: 2.8L V6 multiport
Transmission: 4-speed automatic
Mine sure does
, the driver side rear suspension was leaking fluid...need to get those puppies replaced soon.
, the driver side rear suspension was leaking fluid...need to get those puppies replaced soon. Junior Member
Car: 87 IROC
Engine: 5.7
Transmission: Automatic
According to instructions on the RK SPORT Web site the Panhard will make the car lower on one side than the other if it is not adjusted right (I am not sure if this is for stock or an adjustable one). Visit them for instructions on how to install an adjustable Panhard rod and how to adjust side height if necessary. Seems simple to understand and to do. New Panhard Rods can be bought on e-bay for a reasonable amount. I hope this helps.
Art Heron
Art Heron
Car: 67 camaro ( project )
Engine: 6.7 408 n a snail
Transmission: 4l80 - stalled
Axle/Gears: 3.25 - narrowd tci kit 9 inch
hey i actually just had this problem in my car. make sure the sway bar is connected at all points mine had broken the link, i never would have noticed it driving seemed the same but pass side was about 1 1/2 to 2 inches higher b/c of this.
Car: 88' Iroc-Z
Engine: LQ9
i've never had that problem and ive owned 4 3rd gens? They all sit the same all the way around my iroc has a slight rake to it since i have a larger profile tire in the rear. I'd check springs,shocks, and sway bar endlinks. As that's all that can change the height.
articwhiteZ
Wheels and Tires
45
Aug 14, 2016 01:12 PM
also check your shocks and such make sure you dont have one broke or something like that.
