Drag wheels and tires....
Old Apr 4, 2005 | 12:07 PM
RaMaiRGoD69's Avatar
Car: 88 GTA
I currently have rims that are 16x8.5 with 5 in bs....
What bs should I get with 15x8.5 Note: Needs to clear ebrake lines.
How big of tire will fit on this rim?
I was thinking MT ET Drag Slick 26x10.5
Can I get any bigger on without problems?
Will you give me the part # if possible? (Mickey Thompson ET Drag Slick)
Old Apr 4, 2005 | 12:51 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I'm thinking a 10.5 will be to wide. Check out this post: https://www.thirdgen.org/techbb2/sho...hreadid=287605
Old Apr 4, 2005 | 01:03 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Are you getting Convo Pros? That's the main 15" Drag wheels I know in 8.5" wide.
Anyway, I'd go with 4.5" to 5" BS if they offer something in that range. You should be able to run a 26x10.5 ET Drag or a 26x11.5 ET Street.
Old Apr 4, 2005 | 06:17 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
dude, people put 10.5 drag tires on 8" rims ALL DAY LONG! that flexible sidwall is what makes it possible. with a stiff sidewall tire like you'd find on a 10" wide 18" rim tire, i would say you better have some 18x10's on it.
Old Apr 4, 2005 | 11:23 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i'm running 28x10.50 hoosier slicks on my camaro with no problems whatsoever. just a little pounding. 15x8 rims with 4.5BS check my cardomain site for pics.
Old Apr 13, 2005 | 01:41 AM
Car: 88 GTA
I went ahead and got the 10.5 in wide rims with 11.5 in wide slick... They ended up fitting up just right.
Old Apr 13, 2005 | 10:08 AM
mw66nova's Avatar
Engine: 7.0L
what backspacing did you go with and do you have any pics?
Old Apr 13, 2005 | 02:36 PM
Car: 88 GTA
I used 5.5 in backspacing .... sorry no pics yet... I will try to get some tho... pm me
Old Apr 13, 2005 | 03:11 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Which wheels and slicks did you use?
Thanks,
-Schultzy
Old Apr 13, 2005 | 04:56 PM
Car: 88 GTA
Mickey Thompson ET Drag Slicks 11.5 x 26 for 15 in rim
Weld Pro Star 96 Series 15 x 10 w/ 5.5in bs
Old Apr 13, 2005 | 05:00 PM
mw66nova's Avatar
Engine: 7.0L
does it tuck pretty nice? what kinda "massaging" had to be done to the inner fender?
Old Apr 14, 2005 | 06:23 AM
Car: 88 GTA
The outside edge of the tires are parallel to the top edge of the fender.....
They look like they stick out from a back view because of the shape of the back of the car.
Just to be safe we took out the bumper stops and grinded a little bit on the edges of those mounts. When we were finished we noticed we had about 1/2 in clearance on both sides (from the bumper stop to the side of the slick)
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
buckshot63
Sep 10, 2015 09:15 AM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
