Lug nut thread size for gta wheels
Old Apr 29, 2005 | 07:35 PM
<<K-O>>'s Avatar
Car: 88 TransAM GTA
Engine: 305 LB9
Axle/Gears: Stock
What is the thread size of lug nuts in stock gta wheels? I want to replace my lug nuts with new chrome plated ones. I made a search at summit and I found many options with different sizes. Which sizes will fit gta wheels best?
Old Apr 29, 2005 | 07:58 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
12mm x 1.5
Old Apr 30, 2005 | 03:14 AM
<<K-O>>'s Avatar
Car: 88 TransAM GTA
Engine: 305 LB9
Axle/Gears: Stock
I narrowed my search and I came upon more choices ;
Lug nut shank length ;
0.750 in., 1.380 in., 0.550 in., 1.000 in., 1.700 in.
Lug Nut Head Style ;
Standard and locking, Standard locking, Tuner standard, Tuner standard and locking, Tuner locking
Lug Nut Seat Style ;
Conical seat, Shank, Ball seat
Open end Design ;
No, Yes
Which ones should I choose In these options?
Thanks for the answer Stephen
Old Apr 30, 2005 | 09:47 AM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
standard and locking gives you 4 regular and one locking lug per wheel. so that is your choice if you want locking lugs on your wheels. tuner style is a odd design i don;t like the look of them. it a special key socket to install and remove them. it looks like a gear or spline design.
no idea on shank size
conical seat
closed design, this is a chrome over top of nut, if you say yes to open you will see stud inside nut. not what you want.
usually you order 12x1.5 mm closed design conical seat. that should get you want you need just decide on locks or not.
jeff
Old Apr 30, 2005 | 05:40 PM
83 Crossfire TA's Avatar
Actually, most tuner style lugs have an 8pt star opening which most people don’t seem to know is designed to work with a standard 4 sided 3/8” drive extension. They do make sum that need a separate “key” but they are just 6 sided hexes, just a big allen key like your brake pins use.
As far as what will work for you… the stock studs are fairly sort so pretty much any 12x1.5 lug nut with a 60* tapered seat will work fine. Just choose one you like the looks of.
Old Apr 30, 2005 | 05:43 PM
Oh, and there are also “spline drive” tuner lugs that have 7 or 8 splines on the outside (depending on the brand and design) that sorta look like GM locking lug nuts but the splines are evenly spaced where the GM ones are in an odd pattern to match a key
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
toronto formula
Nov 10, 2015 06:17 AM
Omega
Oct 1, 2015 02:20 PM
knight72
Aug 10, 2015 09:32 PM
