Has anyone ever narrowed a stock('88) rear?
Old Apr 27, 2005 | 08:45 AM
airbrushguy's Avatar
I need to narrow a stock '88 disc rear. Has anyone done this? What's involved and how difficult? I'd like to keep the suspension components (trailing arms, shocks, springs) in the same positions but cut off at least an inch from each side. Is there enough spline to handle the 1" cut or will the axles need to be resplined?
If this seems confusing, it is because I'm putting the rear in a 1939 car.
Old Apr 27, 2005 | 09:03 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Custom axles are the only way to go. It is a LOT of work and if you don't know what's involved, you probably shouldn't attempt it. Need to cut an inch out of the axle tubes near the ends, but you have to cut perfectly and then weld them back up perfectly. Everything has to be thrown into a jig and like I said, perfectly welded.
Old Apr 27, 2005 | 09:36 AM
This is not going to be a "holeshot-type" ride, merely a cruiser with a modern drivetrain. Can the stock axles be cut or do I need to go with custom axles?
I think I and my racecar building friends can handle this, but is there someone who specializes in this, on the East coast?
Old Apr 27, 2005 | 03:00 PM
Car: 1997 Corvette
So you're saying you don't need a perfectly straight rearend to drive around on the street?? At least on the track its only you that gets hurt.
The axles need to be custom. You can't cut down axles unless you have the ability to re-spline them.
Old Apr 27, 2005 | 03:01 PM
Car: 1997 Corvette
I will say it isn't impossible though. I just assumed since you asked what's required that you didn't know what you were getting yourself into. Stupid me judging books by their covers. Its entirely possible, just like how someone around me is making a bolt-in rearend out of an 8.8" mustang center section and 10-bolt axle tubes. You just have to get it EXACTLY straight using a jig or some other setup.
Old Apr 27, 2005 | 03:18 PM
What I meant by only a cruiser is I don't necessarily need stronger axles, just shorter ones. I do have the equipment to respline them, but without opening up the rear I was just wondering if anyone knew whether there was enough spline to use for engagement once an inch is cut off.
Sorry for the confusion, I'm not that familiar with these rears. It will be a cruiser but it definitely needs to go down the street straight.
Thanks for responding.
Old Apr 27, 2005 | 05:06 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
why don't you just run an inch more of backspacing on the rims if that is what you need? this is a lot less complicated than narrowing a very weak 10 bolt rear end.
Old Apr 27, 2005 | 08:06 PM
I don't have an inch of front wheel space to give up.
Old Apr 27, 2005 | 08:29 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You can't cut down stock axles because you'de be cutting off the c-clip that holds them in.
Old Apr 27, 2005 | 08:58 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
Axle/Gears: ford 9in 4:56 to 1
c-clip eliminators would take care of cutting the groove for the c clip off
you would have to measure the shaft
if you used c clip eliminators that automatically take about 5/16th off the end of the shaft thats not needed so it could be real close to being long enough onl;y having to cut 11/16th of the splines. Pull the shafts and measure
Old Apr 30, 2005 | 09:00 AM
Where can I get c-clamp eliminators?
Old Apr 30, 2005 | 12:45 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
You can get C-CLIP elininators from summit or jegs
Old Apr 30, 2005 | 06:26 PM
AlkyIROC's Avatar
Car: 87 IROC L98
But not for the 7.5" diff. Only the 12 bolt or 8.5" 10 bolt.
customblackbird
Aug 15, 2021 10:16 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
sailtexas186548
Aug 26, 2015 03:32 PM
hectre13
Aug 26, 2015 08:17 AM
Exxon Limited
Aug 9, 2015 08:13 PM
