Ball joints
Old Apr 30, 2005 | 01:54 PM
slow83sc's Avatar
Car: 83 camaro sport coupe/ 1981 Camaro
Engine: 2.8 2bbl
Transmission: thm200c
Ball joints
Can anybody tell me how to change the ball joints in the front.
Thanks in advance.
Old Apr 30, 2005 | 06:20 PM
kevinc's Avatar
Car: 1982 Z28
Re: Ball joints
Thanks in advance.
Easy 2-step process:
1.) Remove old ones.
2.) Install new ones.
You might want to snag a manual for more detail.
Old Apr 30, 2005 | 06:26 PM
91blkta's Avatar
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
Do a search this subject has been beaten to death. There are some great treads on this subject.
Old Apr 30, 2005 | 07:52 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
you need a ball joint press, you can rent them at most autozone type places. you have to remove the spindle from the lower joint then press it out with the press. and the press in the new one. best bet is to do a rebuild while your at it. new springs strust tie rod ends ect.
jeff
Old Apr 30, 2005 | 09:26 PM
kevinc's Avatar
Car: 1982 Z28
And try not to kill yourself on the spring...support the A-arm and use a safety chain to keep the spring in place just in case.
Ed1LE
Sep 30, 2018 09:14 AM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
88CamZ
Oct 8, 2015 10:29 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
