Spohn Upper Strut Mounts
Old May 7, 2005 | 04:10 AM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
I need new upper strut mounts because they are creaking. I'm replacing the struts as well. To replace the upper mounts, do I just need to buy the upper strut mounts from Spohn? Do they come with everything I need for the $165???
Old May 7, 2005 | 04:51 PM
JDF-Z28's Avatar
Car: 1983 Z28
Engine: GMPP 350, 92 TPI
Axle/Gears: Auburn gear posi, 3.08
Yep.
Old May 12, 2005 | 02:43 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
i got the ones from TireRack (KYB?) and they work fine, except the old boot does not fit on the top so its exposed. forget the price but you can look it up.
Old May 18, 2005 | 02:46 PM
CaysE's Avatar
Do the boots fit on the Moog pieces (the cheaper ones from Spohn)?
Old May 19, 2005 | 08:28 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
they should since they are the same dim's a the stock ones are.
Kat
Old May 20, 2005 | 02:46 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
The boots or caps fit okay on my KYB strut mounts. Leaving them exposed will decrease the life of the mount's bearing.
Old May 20, 2005 | 03:25 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
Technically you are close, but I want to just politely correct something.
The stock mounts do not have bearings. They have a rubber insert connecting the center metal ring to the strut mount body. This is what corrdes. The dust caps are on there to provide additional protection of the rubber bushing from water or oils getting into there and collecting on top of the rubber insert, thus speeding up there dismay.
Old May 20, 2005 | 03:32 PM
CaysE's Avatar
I think you mean demise, not dismay.
Is there anything like polyurethane grease or something I can put on the bushing every so often to prolong its life?
Old May 20, 2005 | 03:44 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
you can tell I'm no english teacher. thank you CaysE
I have been out of school too long and don't read much of anything to keep up on my vocabulary skills. Terrible of me. To think I graduated Highschool with a B+ average. Lost that years ago. We all know I can't type to save my life either.
I would probably reccommend rubbing the rubber with a fine coat of petroleum jelly.
Old May 20, 2005 | 11:23 PM
Jade Grey's Avatar
Engine: 305TPI
There's no bearings? The center metal ring spins but the rubber insert that surrounds it does not. So is the metal ring bobbin-shaped in profile?
I believe you RTFC because I have never physically disassembled a strut mount from our cars. I just assumed there was a set of ball bearings involved.
Old May 21, 2005 | 03:59 AM
Spdfrk1990's Avatar
What do you guys think about the billet mounts has anyone had complaints out of them.
Old May 25, 2005 | 02:39 PM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
I would consider it a bearing because it rotates freely in the rubber buscuit/mount. It's just not a solid bearing, like the HMS/Spohn ones.
J-money
Jan 4, 2019 09:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
SG91camaro
Sep 5, 2015 10:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
