LCAs and Wonderbar help
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
My LCAs? Neither of them will come off. I can't get my impact on it, because it's too big. I haven't tried with an extension yet, simply because I can't afford $15 for a 4" extension. I did however get one nut off but the bolt wouldn't budge. I was beating on it with a hammer and it wasn't coming out. What now? They're to be replaced with Spohn adjustables
The Wonderbar, also a Spohn product, won't fit. I have heard of fitment problems, but could this be due to a twisted frame or even perhaps damage from a prior accident? Do I install with the suspension loaded or not?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
What doesn't fit on the wonderbar? One of the bolt holes on mine was miss allinged and required me to wallow it out to accept a bolt. The other 3 lined up without a problem.
Car: 1992 Firebird
Engine: forged 357
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
I just went through the same thing that you did a fews weeks back....My holes were off on the srivers side so that the space between then was about 1/4 inch longer than the passenger side LCA...and of course I couldn't put the bolt through the LCA and into the bracket....I was able to use a pully and bring the axel in just a hair and then the bolt slid in nicely...i also needed to heat up all the LCA bolts b/c they were rusted
snakeshooter
Sep 10, 2015 07:46 AM
NBrehm
Aug 5, 2015 07:57 PM
