Did I put the coilovers together right?
Old May 8, 2005 | 03:09 PM
reborn92rs's Avatar
Car: 92 RS
Transmission: auto
I bought Spohn's front coilover kit and some Koni reds and I want to make sure I did things right. I'd like to check I didnt screw up putting the things on the struts in the right order, the instructions confused the hell outta me.
Here is the order I put parts on with the strut facing up:
Threaded sleve,
Large nut with flange facing up,
washer-bearing-washer combo,
Spring -label up,
Washer-bearing-washer combo,
Position plate with flange facing down.
My main concern is with the position plate, the washer combo seems to fit nicely with it facing downwards, but the plate also fits right into the support plates that I bolted up to the car under the strut towers. Which way should it face, up or down?
Heres a shot of the thing incase what I described doesn't make sense.
strut
Anyone able to clarify this so I can get this car to the alignment shop soon??
Old May 8, 2005 | 03:53 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
You have it right. The spring locator plate does exactly that. Center's itself on the strut shaft and then it will center the spring to the strut. So it will always be in perfect alingment with the strut.
Kat
Old May 8, 2005 | 04:00 PM
reborn92rs's Avatar
Car: 92 RS
Transmission: auto
Woot! thanks
Back to work Here is where I left off.
Old May 8, 2005 | 04:03 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Nice!
Some reason all that looks famliar.. Hrmmm
Kat
Jake_92RS
Jan 28, 2020 10:37 PM
dyeager535
Aug 28, 2015 08:10 AM
michealleger
Aug 26, 2015 03:29 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
Fronzizzle
Aug 9, 2015 01:15 PM
