spring lift/lower problem
Old May 11, 2005 | 09:32 PM
brightonrock's Avatar
I have a 92 vert with Eibach springs. The problem is I built a sub-box into the trunk of the car and with the weight if the stereo, it sits a bit to low in the rear. Is there a quick fix..ie a spacer that can go into the springs to raise the car a bit? Or should I do something with the front to lower it to match? Any weblinks to products would be great.
p.
Old May 12, 2005 | 12:43 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
Axle/Gears: ford 9in 4:56 to 1
94 - 02 rear spring isolators will raise it about 1- 1 1/2 " over stock
customblackbird
Aug 15, 2021 10:16 PM
Street Lethal
Apr 30, 2019 12:14 PM
sailtexas186548
Aug 26, 2015 03:32 PM
TheExaminer
Aug 25, 2015 07:34 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
