koni red struts or some other setup?
Old May 14, 2005 | 03:13 AM
luke4907's Avatar
Car: '89 Trans Am GTA
Engine: TPI350
Axle/Gears: BW 3.27s
Hi, I'm interested in opinions as to whether or not it would be worth it to ship some struts back to koni for replacement / rebuild, which will probably cost a bit, or just save my money and put it into a coil-over setup or something else if anyone has suggestions. The rear Konis I pulled from my friend's car were fine, but the fronts had barely any rebound at all. Adjusting them wouldn't fix them if they are this bad, right? Any opinions appreciated. Thanks
Old May 14, 2005 | 05:55 AM
CrazyHawaiian's Avatar
Car: too many ...
I'm running Koni Reds on my 91Z28 and I'm really happy with them. I got both the front and the rear on the hardest setting. I might send the fronts in for rebuild soon, the rears are fresh and they seem a little bit stiffer.
Old May 14, 2005 | 10:12 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
These aren't gas-charged struts, they shouldn't move much when you compress them I didn't think.
Old May 14, 2005 | 10:41 AM
luke4907's Avatar
Engine: TPI350
by the same token they shouldn't be very easily compressed, should they?
Old May 14, 2005 | 11:24 AM
Car: 1997 Corvette
Exactly, depends on the setting of the strut though. To adjust them, you need to compress them all the way. Mine are on their softest setting right now with my stock springs (the struts are fairly new). I've put quite a few miles on them now as they are, so whenever I get my front lowering springs installed, I'm going to kick the stiffness up a bit.
J-money
Jan 4, 2019 09:45 AM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
TheExaminer
Sep 28, 2015 02:28 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
SG91camaro
Sep 5, 2015 10:27 PM
