Welding differential tubes while on car?
Old May 16, 2005 | 11:52 AM
mult68's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
I just put in another rear end in my car. I had to do it quickly so I didnt get a chance to weld the tubes and paint everything before I put it in. My question.....when I go get the LCA brackets welded on.....will they beable to weld the tubes as well? First will they have enough room to go all the way around....and can they weld it with the axles and lube in there? I guess it probably wont make much of a different have the tubes welded or not....but if its possible I'll go ahead and have them done as well. Thanks for the info.
Old May 16, 2005 | 09:53 PM
batchik2's Avatar
Car: '86 Z28 Chassi, '91 V8 S10
Engine: 350 bored .030 new cam, #416 heads with 1.94" intakes
Transmission: S10-NV3500 5spd
if its a 10 bolt the axlehouseing is probly the last thing you need to worry about. i wouldnt waist the money/time if its already in the car. but if its a 12 then go for it. i wouldn't thing it would be a problem.
Old May 16, 2005 | 11:50 PM
83 Crossfire TA's Avatar
There’s probably enough room with the axle at full droop. But there is no way that you’d do a good job at it and keep heat even enough to keep from warping the axle.
Even if that wasn’t the case I still wouldn’t do it with any lube in the housing or with it too assembled that you couldn’t thoroughly clean it out afterwards.
Old May 17, 2005 | 05:29 AM
ede's Avatar
ede
yeah it shouldn't be much of a problem to weld. might want to pull the cover and drain the oil before you get started with the welding.
Old May 19, 2005 | 07:49 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I found a great how-to on axle welding while researching my recently aquired '70 Camaro. Look here:
http://www.nastyz28.com/ubb/Archives...12-005454.html
Ed
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
mustangman65_79
Aug 13, 2015 07:36 AM
mizz0313
Aug 12, 2015 06:45 AM
