Nitrogen
Old May 18, 2005 | 07:40 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Nitrogen
I was reading an article about how some places are using nitrogen insted of compressed air to fill tires up. The compressed air is susposto make the tires age faster and can damage the rims it said. My mom took her car in for a rotation and balancing the other day and they used nitrogen in her tires to fill them up. Anyone hear anything about this?
Old May 18, 2005 | 08:20 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Compressed air is full of moisture. Nitrogen is an inert, nobel gas. Some race cars such as Indy etc will use nitrogen because it won't be affected as much with temperature changes. Compressed air in a tire will change pressure. Pressure will increase as the tire heats up and pressure will drop when it gets cold.
If a shop is using nitrogen to fill tires, they must be charging the customer back. Compressed air just takes electricity to make air pressure. You need to buy nitrogen. I use nitrogen to test AC systems since I don't want the water vapor of compressed air inside the AC lines.
Once your tires are filled with nitrogen, how do you intend to top them up when you check pressure once a month? As soon as you add compressed air, you've defeated the purpose of having nitrogen in them.
Old May 19, 2005 | 12:54 PM
irocdan's Avatar
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
i sell welding supplies gases and cryogenic liquids.nitrogen is the way to go,its cheap too.pm me if u want more info
Old May 19, 2005 | 03:13 PM
CrazyHawaiian's Avatar
Car: too many ...
Yeah this happened to my G/F's car recently. They did it for free. They use a green valve stem cap right? I also wondered about topping it off if/when it gets low. The guy said to bring it back and they'll fill it for free.
For my drifting I'm still using the good old compressed air (mainly because my friends shop didnt get nitrogen yet).
Old May 19, 2005 | 03:21 PM
FAST RS's Avatar
Ya they put on green caps.
Old May 20, 2005 | 01:22 AM
83 Crossfire TA's Avatar
most of the advantage is just the dry air. Most of the negative side effects (conversely the advantages with N) are the result of compressed air usually having a lot of water in it.
Old May 20, 2005 | 12:25 PM
irocdan's Avatar
Car: 88 Iroc vert
actually it not having fluxuation in tire pressure reguardless of the temps between cold tired and warmed up tires
pigsticker
Wheels and Tires
32
Jul 17, 2011 12:49 AM
Wolfskin
Feb 25, 2010 01:47 PM
sellmanb
Nov 4, 2004 02:21 AM
PETE
Nov 26, 2002 03:21 PM
