Front Sway bar removal
Old May 19, 2005 | 04:12 PM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
Transmission: Powerglide
Axle/Gears: Moser 31 spline / 4.86
How will this effect my car? The car is strickly drag running 6.90's in the 1/8th. The front sway bar looks pretty heavy, just wondering if I can remove it without any problems. The front end is tied down if that makes any difference.
Old May 19, 2005 | 04:17 PM
ss86's Avatar
Car: 78 Malibu
Engine: 357
Not only will it save a little weight, but it should help your weight transfer too. Go for it!
Old May 19, 2005 | 06:48 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I agree with ss86, go ahead and take it off. It will drop some weight and help weight transfer. I just took mine off a few weeks ago. It won't hurt anything especially since you don't drive on the street....just makes the car handle worse on curves.
Old May 20, 2005 | 02:51 AM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
well I took it off, along with the front impact bumper and the rear impact bumper. Not sure on the total lbs. taken off, but that should help me out a little bit..
Old May 20, 2005 | 11:28 AM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
We have a winner.... So when you hit something, you motor will stop it from getting into your cabin... I cant say that is a good way of doing it.. is this car roll caged (Completely)?
Old May 20, 2005 | 02:44 PM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
yes, full cage, SFC's, it will never see the street. If I hit something head on at the track, then something is wrong.
Old May 20, 2005 | 02:46 PM
Car: 85 Trans Am
Well than i guess you know the risks
/endconcerns
Old May 20, 2005 | 06:23 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
SAFTY ***** suck
Old May 20, 2005 | 06:46 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Originally posted by Tony Walch
SAFTY ***** suck
Yeah, almost as bad as those Spelling ones. Oh, by the way it's spelled "SAFETY".
Lon
Old May 23, 2005 | 09:26 AM
TTOP350's Avatar
Had to typ fast on lunch brak
Old May 23, 2005 | 11:44 AM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Not sure about the weigh on Camaros, but the weighs for the impact bars on my '90 Formula were 35lbs front, 25lbs rear, and 15lbs for the 36mm front sway bar.
I'd say somewhere in the neighborhood of 75lbs give or take 5-10.
Old May 23, 2005 | 04:25 PM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
It picked me back up at the strip. Before in the heat i could only manage to run a 7.04.. Saturday night i went out to make a few time runs and the first 2 i spun out of the hole a bit and went 7.02 both runs, then lowerd the tire pressure to 10 1/2 lbs. and went to the right lane and went 6.97 @98. So i'd say it made the difference i was looking for. I just put on a set of M/T 29.5x10.5 tires from my 28.0x10.5's so im anxious to see if that helps my 60ft. as well as mph this coming weekend.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
3rdgenparts
Aug 8, 2015 07:09 PM
