Chirping sound in the back
Old May 24, 2005 | 01:05 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Kinda like a bird's chirp chirp .. not constant.. but every now and then ... what ya guys think ... U-joints ?? I did push down on each corner of the car so I don't think it's the shocks
Old May 24, 2005 | 10:43 PM
92'Sleeper's Avatar
Car: 92' B4C Camaro
Transmission: G-Force T5
I had some chirping sounds awhile back. Like you said it wasn't constant at first, then after awhile it became constant. I replaced the U-joints and the problem was gone. Try the U-joints, their cheap and easy to replace.
If you are going to replace them yourself and they are the factory U-joints with the Teflon nipples you will need to heat the Teflon until it drains out before you go beating the old U-joints out.
If not, it shouldn't cost no more than $40-$60 for a lacal shop to do it for you.
Old May 25, 2005 | 12:09 AM
83 Crossfire TA's Avatar
I’ve got a twisted axle in mine and that causes the rear caliper to move relative to the backing plate as the tire goes around causing a squeaking like that. Sometimes it almost goes away, sometimes it does it all the time, but most of the time it’s just a once in a while thing, sounds just like brake pad wear indicators but doesn’t act the same.
Old May 25, 2005 | 01:32 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
ok
Well I'm still bringing the car back to the dealership when things pop up.. since I figured sure I can do it myself but.. WHY .. if they can pay for getting it done ya know... the mroe I can save on parts the better... saves me money that I'll eventually need for damn tires
Andrew6.688
Dec 13, 2015 10:59 AM
db057
Aug 22, 2015 08:17 PM
midias
Aug 22, 2015 01:42 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
gwade12
Aug 8, 2015 08:17 AM
