Question about Strut Dust Covers
Old May 24, 2005 | 11:15 PM
CrazyHawaiian's Avatar
Car: too many ...
Just wanted to know if anyone else runs their struts with no dust cover? The car I'm installing on will be pretty much track only, not daily driven, so I'm considering it. But I'm worried about dirt damaging the seals. If anyone else has done it, I'd like to hear about your experiences. Thanks!!
Old May 25, 2005 | 01:08 AM
vjo90RS8's Avatar
Car: 2002 Z28
why would you want to run without them, they only weigh about an ounce each, and its not worth the risk to the bearing.
Old May 25, 2005 | 04:43 AM
Car: too many ...
Two reasons, first the OEM shields are stuck on the old strut/mount units, whoever installed it last overtorqued the top nut way too much and its not possible to loosen (strut shaft spins with the nut). Only way to do it is hold the dust shield steady with a vice but this will damage the shield (its already bent, not cracked yet). I've sprayed some WD40 on the nut, gonna let it sit overnight and try again tomorrow. Second reason is I'm running aftermarket strut mounts as the replacements and I dont even know if those OEM shields will fit if I ever happen to get them off the old parts.
It would be much easier to run them without the shields, but I wanna do it right so I figgured I would ask and see if anyone else is doing it and what kinda issues they might be experiencing.
Old May 26, 2005 | 12:02 AM
83 Crossfire TA's Avatar
I had a car that just didn’t have room… thought about using some 4x4 shock boots but didn’t have time to get them when I had the car apart so I just took some polyethylene sheet, wrapped it around the area a few times and zip tied it on the top and bottom. Worked great for years
Old May 26, 2005 | 02:14 AM
Car: too many ...
Thats a great idea! I might give that a try. Thanks! I finally got one of the nuts off (drivers side unit) but the shield is all mangled. Ended up I was wrong and the shield is not the only way to hold it steady (feel so stupd now) was able to use two wrenches and two cheater bars and loosen it, no contact to the shield needed. Feels like I manhandled them for nothing now. I test fit the shield in my HMS mounts and it does fit. Might bend it back into shape, sand, and paint it. Still gotta think about it (and finish polishing the pass side mount).
Old May 26, 2005 | 04:42 AM
3rdGenBlackBird's Avatar
I don't have about half of the boots on the front of my maxima. (CV joints are all good, though.)
Haven't had any problems yet.
Still wouldn't recommend it....
Scott
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
