idler arm installation question (rotate it?)
Old May 27, 2005 | 01:02 PM
Nokternal7's Avatar
Hello,
My replacement idler arm is in a different orientation than the one I just took off my car. In other words, if both idler arms (replacement and original) were bolted to the car, the section on the replacement idler arm that connects to the center link would point in a completely different direction.
Do these idler arms need to be rotated to the correct position before being installed? It seems like a lot of force would be needed to rotate it.
I can send pictures if this description is not clear.
thanks a lot
Old May 27, 2005 | 02:26 PM
CaysE's Avatar
I just put the flat end that bolts to the frame in a vice. I was able to rotate it to the correct position that way by hand. It takes a bit of force, as they should... but they will move.
[edit] You could also just bolt it to the frame and rotate it there.
Old May 27, 2005 | 02:30 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
IROCZ1989
Aug 19, 2015 08:15 AM
redmaroz
Aug 16, 2015 11:40 PM
