How safe is this?!?
Old Jun 4, 2005 | 09:59 PM
Gr89RS's Avatar
Car: '02 Z06
How safe is this?!?
I ordered the Eibach Prokit (arrived) and Tokico HP strut/shock kit and i dont have the budget for an ajustable panharb bar at this time, will i be okay in stalling my new parts without it??Thanks alot.
Old Jun 5, 2005 | 01:18 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
You may luck out as I did and find you don't need an adjustable PHB to re-center the housing. I too have Eiback ProKit lowering springs. I measured the distance from rim to lip on each side and round I'm within 1/16". Not enough to worry about IMO. Do the swap and take the measurement using a yardstick or long level vertical at the fender lip on each rim.
The bigger problem to worry about will be correcting the angle of the rear LCA's once you've lowered the car. You'll need a set of LCA relocation brackets (bolt in or weld in) to return the lower control arms to the correct angle. If you're unfamiliar with the concept, do a search. LCA relocation brackets have been discussed many times in detail.
Lon
Old Jun 5, 2005 | 08:00 AM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Im running the same shocks and struts and i didnt come down much at all compared to the 23 year old springs that were in there.
You shouldnt notice the difference in the rear too much. I say throw your stuff on and see what it does. And if your planning on getting the trackbar when you have the money dont worry about it yet.
I'll try to get some new pictures of the car here soon, but i cant take it anywhere to shoot it, i dont have my exhaust on.
86IROC112
Nov 27, 2015 09:54 AM
roysatikas
Sep 22, 2015 08:15 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
UMI Performance
Sponsored Vendors
Sep 4, 2015 09:22 AM
UMI Sales
Sep 4, 2015 08:39 AM
