SFC's ... suggestions ?
Old Jul 5, 2005 | 12:31 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
OK, so far I know there's tons of different SFC's out there .. my questions are as follows:
I plan on getting bolt-in SFC's .. and later on weld them in as well .. now my question is ... alignment of the bolt-in SFC's .. is there any drilling involved.. or.. a straight run the car up on a drive-on-lift.. raise it.. bolt the assembly in ... and good to go (and weld it later on) .. or .. what ?
Tubular is supposed to be better... but... is it better than the real big diamond shape square tubing SFC's ?
And what's better to get anyway ... those SFC's that go side by side with your own frame rails ... or the ones that go more in the middle ...
For instance.. what about these ones
http://www.hawksthirdgenparts.com/in...?v=1&pid=13763
And what about the Kenny Brown SFC's ?
As far as money spent on SFC's .. I'm like this ... the SFC's will be in the car for "quite some time" *lol*.. so if I have to spend 350 rather than 220 ... fine I'll wait for a lil'while longer and save up on money and do it ... I want to have the good rock solid ones
bolt in first.. later on weld in
Old Jul 5, 2005 | 02:51 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
i bought the CGS ones off of ebay.
i tired fitting them up, and they ddin't quiet fit perfectly
the stock y pipe hits it
and the bends in them weren't perfect enough to contour to the floor
i'd recommend spending decent $$ on either TDS or Sphon
that's what i will do next year
Old Jul 5, 2005 | 04:37 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
What ?
Are you serious ? .. T H A T bad ???
Pac J
May 17, 2020 10:44 AM
Mark_ZZ3
May 24, 2018 01:02 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
383backinblack
Oct 14, 2015 08:50 PM
gord327
Oct 3, 2015 01:25 PM
