building a structure
Old Jul 7, 2005 | 05:12 PM
1bad88droptop's Avatar
Car: 88 camaro drop top custom
Engine: turbod lt1
Transmission: t56
what is the best way to structure up a 88 iroc convt. for about 500 horse?
Old Jul 7, 2005 | 09:56 PM
camaro_1983_383's Avatar
your fighting a losing battle, but if you insist... if you didnt ever put the top down you could put in a cage, but thats probably out of the question. Get the beefiest weld in subframe connectors that you can find. Then have a race fab shop add to them as much as possible, lol. most good strong subframe connectors will restrict exhaust options resulting in crappy ground clearance. My buddy cracked a windshield in his T-top car from twisting. He had very good traction with less HP than your talking about.
Old Jul 7, 2005 | 10:17 PM
Engine: turbod lt1
Transmission: t56
well what would u say is the most amount i should run on a beefed up suspension?
Old Jul 7, 2005 | 10:45 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Run all the power you want. If you want the most in rigidity run both Spohn and Alston subframes.
Old Jul 7, 2005 | 10:56 PM
Engine: turbod lt1
Transmission: t56
ALRIGHT, THANKS FOR THE INVITE
Old Jul 7, 2005 | 10:58 PM
Engine: turbod lt1
Transmission: t56
OR THE ADVICE I MEANT
Old Jul 7, 2005 | 11:04 PM
Engine: turbod lt1
Transmission: t56
Old Jul 8, 2005 | 07:08 AM
Wolfpack's Avatar
Car: 86 Iroc
You can Run both? How does that Restrict the Exhaust Options? Anyone Got pics of both of them installed?
Old Jul 19, 2005 | 12:39 AM
83 Crossfire TA's Avatar
Get some good size box steel tubing and find a chassis/race car shop that knows what they’re doing, have them use the box stock to tie the subframes together thorugh the floor, welding the floor to them the whole length. Add a decent roll bar, some seam welding… and it will live fine.
There are 9second f-body verts out there...
ZEEYAA
Apr 16, 2023 08:29 PM
racereese
Oct 3, 2015 03:46 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Zell1luk
Sep 29, 2015 10:36 AM
Jlanz55
Sep 29, 2015 08:55 AM
