need help on tire pressure and launch
Old Jul 25, 2005 | 02:09 PM
rock'n z's Avatar
Car: 88 camaro iroc
Engine: 5.7 tuned port
Transmission: 700 r4
i reacntly went to the track and i brought my mickey thompson et's i ran on 12 psi and launced at 1500 i was wondering what would help me get lower then a 1.90 60 foot and a 14.00 et will lower tire pressure and a higher launch work will i even be able to bring my rps higher at the line with out brakein loose at the line?????
Old Jul 25, 2005 | 03:43 PM
brutalform's Avatar
Seems that 14.5 p.s.i. is the magic number for most third gens, at least its a good starting point. It would be best to experiment though. I usually do a good burn out, and roll out of it. I never do a dry hop either. Then bring you engine up against the converter. I go as far as I can before the car wants to move foward. Hold those brakes hard. Wack it on the last amber. Keep an eye on the tire pressure, as sunlight directly on a tire will increase its pressure. In the staging lanes give the tires one more quick check. BTW, a 1.90 60ft. is not too shabby for a near stock car. What do you all have done to your car anyway?
Old Jul 26, 2005 | 02:41 PM
rock'n z's Avatar
Car: 88 camaro iroc
well i have headers exahust underdrive pullys afpr and airfilters i also have a 2200 stall with a tci rebuild and a shift kit but in street tires i was pullin 1.95 60 ft but now 1.90 i give it a good burn out but this time i guess ill bring it up to the stall limits and see what happens and ill also sit up against the steerin wheel to hold the **** outta the brakes
Old Jul 26, 2005 | 03:41 PM
brutalform's Avatar
Yes, I would give that a try. I just might help. Like I said, just experiment. Then you can work on your shift points.
Old Jul 26, 2005 | 10:23 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Another trick too that works for some cars, sit there at an idle till the last amber. You worried about car performacne, not driver R/T performance, some cars like getting a run at the convertor, especially in footbraked car, just one more thing to try while your playing
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
mike_c
Aug 27, 2015 04:32 PM
g.l.mos
Aug 22, 2015 12:02 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
