what springs
Old Jul 28, 2005 | 08:06 PM
boredomkills's Avatar
Car: 1992 rs
Engine: 350 tbi
what springs
i need some stiffer springs all around i have an rs but have done a 350 and other stuff and now i m getting to the handling since i have an rs the springs are slightly softerthan the Z28 should i go to 1le springs or after market and because of my driveweay i need atleast stock ride hight
Old Jul 28, 2005 | 09:00 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
If you need the stock ride height you will need to look into factory moog replacement springs. However, there is a good chance your currect springs are sagging. Therefore, any 1" drop aftermarket spring could keep your car at he same ride height that it is now. I would do some reading here on TGO about lowering springs. Use the search function to read up on the various springs offered for our cars.
Old Jul 29, 2005 | 08:07 AM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
A cheap way to go would be to go to Advance/Orieleys/Autozone, etc. and get some stock Z28 replacements. That's what I'm planning on since mine are sagging. It'll run a little over $100 for both of them.
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
