View Poll Results: Hollow bar vents on top or bottom?
Top (facing the sky)
33.33%
Bottom (facing the ground)
66.67%
Voters: 18. You may not vote on this poll
Sway bar "vent" holes on hollow bars...
Old Aug 1, 2005 | 09:44 PM
JPrevost's Avatar
Car: 91 Red Sled
Are your vents on the top or bottom? The holes should be near the endlink and pointing either up or down. Please vote if you can take a minute and look on your car. If you've got a picture of a bar with the vents on one side or the other, might use that digital camera that's been sitting for a while .
Old Aug 1, 2005 | 11:44 PM
1983sc's Avatar
Car: 00' rcsb
Engine: Little boosted 5.3
Transmission: 4l80e
the bar on my old 83 was facing the sky, (bar was a 36mm from a ws6) but all the same, the holes were facing up
Old Aug 2, 2005 | 08:16 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
I looked at one on a 85 T/A at the junk yard the other day....... the holes were pointing up.
Old Aug 2, 2005 | 08:47 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
mine were facing down. i assume the bar had never been touched since all the bushing were rotted
Old Aug 2, 2005 | 09:50 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
i don't think it matters, but since it is a "vent hole" i'd do it facing down so if any water got inside it wouldn't pool and rot the bar
Old Aug 2, 2005 | 11:32 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I'm thinking that the only purpose of the holes was for the manufacturing process. The might have been used to vent the bar during heat treating or some other process after the ends were closed. I don't thing they are there to vent water...
Old Aug 3, 2005 | 12:07 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If that's true then it's interesting that they're always up or down, instead of in some arbitrary position.
Old Aug 3, 2005 | 12:36 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Or they could be used to align the bar for the bending and other manufacturing process. I really have no clue just speculation.
Maybe the bars were made by different outsourcing companies or different plants
Old Aug 3, 2005 | 08:27 AM
CaysE's Avatar
There's a good question. List what plant your car came from, too.
Old Aug 3, 2005 | 01:21 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I doubt swaybars were made on site at the assembly plant.
Old Aug 3, 2005 | 01:26 PM
CaysE's Avatar
But they have been made for specific plants. Just a thought.
Old Aug 3, 2005 | 04:18 PM
JPrevost's Avatar
Car: 91 Red Sled
I doubt they're drain holes but what really confuses me is why they left them open to rot from the inside out. After production they should have used some rust preventative inside, some inert gas like nitrogen and then sealed it off. That would have been ideal... but we got GM... the penny pinchers of the automotive world
Old Aug 3, 2005 | 10:53 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Yeah i think it's a little beyond GM to go that far!
mine pointed upwards, it was an 85 Z, from van nuys.
Old Aug 3, 2005 | 11:02 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Actually we need to know if the bars are 34 or 36 mm. Mines a 36 with holes down.
Old Aug 3, 2005 | 11:42 PM
JPrevost's Avatar
Car: 91 Red Sled
36mm up
Old Aug 4, 2005 | 08:11 AM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
36 down
Old Aug 4, 2005 | 11:52 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
34 down
Old Aug 4, 2005 | 08:56 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Mine's a 36 down. Oddly, I sold several set of those at one time. All the holes were down.
JamesC
Old Aug 4, 2005 | 10:16 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
One of these days I'll get some time to check my inventory and report the results for the 34mm & 36mm bars in stock. Yes I've seen both up and down oriented holes.
Lon
Old Aug 5, 2005 | 10:10 AM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
Look at the ends of the bar to see if the endlink-ends were welded to the hollow tube.
If so, then they are vents holes to prevent the inside air from blowing out the weld when the weld is still liquid. It's a std practice when welding a closed pipe to leave a hole for that purpose. Closing off the hole (after the welding) to prevent moisture/water ingression would be a good idea but apparently no one here has ever done it. And if it didn't affect the function of the sway bar (interference of any kind, and symmetric bar in an up/down sense), then mounting the bar with the holes facing the ground is probably preferred for reasons that should be obvious (they drain). FWIW.
Old Aug 5, 2005 | 11:34 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The ends aren't welded, just stamped IIRC.
Old Aug 5, 2005 | 10:55 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Yep, it's a hollow tube that is bend and the ends are crushed to form the endlink.
Old Jan 10, 2009 | 11:30 PM
JPrevost's Avatar
Car: 91 Red Sled
Re: Sway bar "vent" holes on hollow bars...
Back from the dead... but just re-read this old post and if they were vent holes for welding... why would there need to be 2 holes made? One would have sufficed if the tube is in fact hollow the whole way through.
I still have no idea why they are on the tubes if only to indicate at a glance that the bar is infact hollow? Maybe that was an indicator for the dealer and repair similar to the tag on the rear cover about the posi. I mean it isn't as obvious but it is noticable and 2mm on bushing size doesn't sound like much but it makes it HARD to put the brackets back on if you're using the smaller 34mm bushing!
Old Jan 11, 2009 | 01:33 AM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I've had 2 36mm bars that were facing up, 3 36mm bars that were facing down, and 4 34mm bars that were facing down.
Old Jan 11, 2009 | 01:50 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A sticker or stamped part number would be a more cost-effective marking than a drilled hole.
Old Jan 11, 2009 | 07:41 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I am thinking they used the vent holes to allow the welding process to work correctly.
Old Jan 11, 2009 | 12:16 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Pretty sure mine are down, hollow 36. I'll double check.
Where the crap you get that many bars?
Old Jan 11, 2009 | 12:54 PM
Car: 1987 IROC-Z
Transmission: TH350
Unfortunatly, none of the bars I have/had had the tag with the part number still attached.
I have cleaned out a couple junkyards. I figure rather then let them possibly get crushed, I'll pull them out and sell to other TGO members. However, I probably won't be getting more any time soon since the local junkyards don't have any of the desirable bars any more. There are still plenty of rear bars that can be grabbed, but those can wait until spring because I don't want to have to go out in the snow atm.
Mike
Old Jan 11, 2009 | 12:56 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Brave the snow and find me a 21mm rear. I shall pay you upon graduation lol.
You're lucky, our junk yards have about 3 cars between them.
Old Jan 11, 2009 | 01:19 PM
Car: 1987 IROC-Z
Transmission: TH350
Maybe when the snow melts a little. There is about 6" of snow on the ground right now with more coming in the next couple days, but I might have a 21mm rear bar in the garage.
I know I'm lucky. There are 21 thirdgens and 8 fourth gens at a single junkyard and it is only about 5 miles from my house. Score!!
Mike
Old Jan 11, 2009 | 03:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I don't think there's any welding anywhere on the bar.
Old Jan 11, 2009 | 03:32 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Mike
I was just messing with you. I'd like to have a 21mm to tune with, but I won't be able to buy one for some time. I wish I had that many f-bodies near me. Come summer, I may send you a laundry list of things lol.
Old Feb 9, 2009 | 07:37 PM
blp226's Avatar
The holes are to help control condensation.
J-money
Jan 4, 2019 09:45 AM
camaro1185
Oct 26, 2015 06:51 AM
J0386
Oct 12, 2015 07:46 AM
87camaro87
Sep 9, 2015 10:29 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
