steering shake....
Old Aug 1, 2005 | 10:08 PM
pskel350's Avatar
steering shake....
at idle or slower speeds my steering wheel shakes really bad. there is no play in the steering at all, just a bad shake.
could it be the box? it has about 135,000 miles on it. never been opened up or adjusted.
i have a lsx swap, could it be the stock ls1 pump is bad? or not able to supply enough pressure?
at highway speeds, or anything about 30 mph is perfect. just low speeds or stopped at a light it shakes.
any ideas
Old Aug 2, 2005 | 12:45 AM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
Wha??? Open underneath the hood and see where the shaking is starting. I'm betting it will be the intermediate shaft going into the steering box. Does it do it when the wheels are at a full lock on either direction or when you try to turn it at a stop? My only guess is something is wrong with the PS pressure and/or the hoses from an LSX swap. Does the pump make any noise?
Old Aug 2, 2005 | 02:49 PM
pskel350's Avatar
pump is dead silent, no whining or anything. it will shake with wheels straight while stoped at a light.
Old Aug 3, 2005 | 02:27 AM
Engine: Your Momma
From a dead stop it does it, does it go away with higher RPMs or a least lessen, like if you were to rev the engine at a stop. Or is the vibration relative only to vehicle speed and not engine.
Old Aug 5, 2005 | 01:28 AM
Kandied91z's Avatar
that's odd, i had that problem going over bumps and it was the pump. sitting still i have no clue, let me know if you figure it out though..
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
