Can't find any performance shocks that aren't lowering?
Old Aug 15, 2005 | 11:35 PM
Project's Avatar
Car: 85 Camaro Z28
Transmission: 700-R4
I cannot lower my third gen, I go through dips 10 times a day and rub occassionally, I can't lower, but I need new springs/shocks...
any suggestions?
Old Aug 15, 2005 | 11:43 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Your shocks/struts do not set ride height. And there are plenty of shock/strut combos designed around stock height springs.
So what's your problem?
If you are just looking for a suggestion, I like Bilsteins.
Old Aug 16, 2005 | 12:27 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
springs determine ride height
Old Aug 16, 2005 | 01:22 PM
Bens3rdGen's Avatar
Car: 91 Camaro RS
Engine: Holley MPFI, AFR 195, Hot Cam=375HP
Bilsteins are good, got em on mine. I've also heard Koni yellows are good, haven't tried em though. Both will work for stock ride height
customblackbird
Aug 15, 2021 10:16 PM
LT1Formula
Nov 16, 2015 01:13 PM
NBrehm
Aug 25, 2015 11:49 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
