not happy with pa k-member
Old Aug 12, 2005 | 03:40 AM
NOSFEDGTA's Avatar
after countless hours i finnaly have my k-member in. I started at like 5 or so and got done at 4am. now I have use of air tools, a lift and my motor was already out of the car! it fit the chassis well but damn the control arms would not go in for shiz!!!!!!!!!!! i ended up cutting a huge "window" in my control arm to make them fit!!!!!!!!!!!!!!!!!!!! it took me several fittments to get it right ! now I have to box in the bottom of the control arm to strengthen it back up. I had to take a big chunk out for it to work properly!!! all it would do is bind on the main hoop where it bends upwards. i am not a happy camper. I will be calling them to let them know it didnt fit for crap.......
now there customer service was good to me I will sya that. I had to swap this one for one I had that had no spring perches. so I cant complain about that...
I am still very aggrivated, and tired.........
Old Aug 12, 2005 | 06:56 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check the following link:
https://www.thirdgen.org/techbb2/sho...hreadid=309374
JamesC
Old Aug 12, 2005 | 07:15 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I know people have had huge problems with theirs. I have read all the threads.
I just want to say that I bought mine way before I knew about TGO and its vast ocean of wisdom. I got it off ebay shipped to my door with perches and A-arms for $575. I have my motor out and tossed mine in, in about 45 minutes max. And that is only cuz i had to go back in the house to find the right bolts.
Fitment was perfect and the A-arms sit in there just right. The only thing I had to do was lube up a bushing to have it slide in better. THat was it.
plenty of pics on my site
Just my 2 cents.
Old Aug 12, 2005 | 08:01 AM
FORMULA355TPI's Avatar
Car: 88 FORMULA / 88 IROC
Engine: 355 / 355
Transmission: T5 / TH400
Axle/Gears: 10 Bolt-3.73 / 9"-3.90
Just wait till you try to turn it that rack has a turning radius of a mack truck..
Old Aug 12, 2005 | 08:09 AM
Engine: LS3
Dunno if you are reffering to me, but I am not running a rack. I am running an aftermarket manual streering box. If you are reffering to the guy that had the bad experience then my bad for butting in.
Old Aug 12, 2005 | 01:40 PM
Kandied91z's Avatar
Just my 2 cents.
have to agree, i guess those of us who got in early were lucky.
Old Aug 13, 2005 | 05:29 AM
NOSFEDGTA's Avatar
well part 2 is here!!!!!!!!!!!!!!!!!!! after another many ours I finnaly got the motor in. it took me 4-6 hours just to set the damn motor in the car!!!!!! the motor mount bolts would not line up for ****!!!!! I ended up having yo use 2 diff bolts on each side to get it to work! this pa **** is not worth a damn!
Old Aug 16, 2005 | 02:46 PM
Engine: LS3
sux man. Hope it all works out for you. I will be tossing my new motor in soon. i will post how easy it is to put in.
InfernalVortex
Apr 20, 2021 11:31 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
buckeyecelt
Sep 24, 2015 05:50 AM
Mdenz3
Sep 17, 2015 08:36 AM
