loose feeling front end
Old Aug 17, 2005 | 02:16 AM
87pontiac's Avatar
Car: 87 Firebird
Engine: 2.8l-(350 on the way)
Transmission: auto-(for the wife)
Hey People,
I have a 1987 Firebird with a V6 (2.8L).The car seems to wonder and the steering feels loose.The brakes are fine so I know it isn't pulling due to a grabbing brake.
I have heard that the steering box could be worn and need adjusting. The balljoints on my car could need replacing because the wear indicator ,I think they say they do. The wear indicator ,if I'm correct, is the distance from the grease fitting nut to the base of the balljoint. If this is right ,the grease fitting nut is not visible anymore. The only thing visible is the round part of the fitting itself along with a slit(1/16" opening), in the base of the balljoint.
My question is , what parts usually wear faster on these vehicles and has anyone ever had to adjust there steering box?
Thans for the help
Ron
Old Aug 17, 2005 | 12:43 PM
86LG4T56's Avatar
Car: 1986 Firebird
Engine: LG4 305
When I replaced my centerlink and idler arm, my steering got noticably tighter. Made such a difference on the interstate it put a big smile on my face.
Old Aug 17, 2005 | 01:11 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
There's a lot of threads here on what to check and how to check it. Please, however, resist the urge to tighten your steering box until you have eliminated all other possible causes. Over adjusting the steering box will kill them fast-causing tracking and overcorrection problems. They also the most expensive item to replace between your steering wheel and the tires.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
bellez77
Sep 5, 2015 08:39 PM
flash2042
Exterior Parts Wanted
Aug 7, 2015 05:58 PM
