Lowering spring question. V8 car with V6 springs will it sit lower???
Old Aug 17, 2005 | 07:26 PM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
Hey guys, I love the look that the Eibach Sportlines give the car, but I am running long tubes and I know that with the linear springs I'll be hitting everything. It was at that point that I decided to just use the Pro Kit. But when I started thinking about it, why couldn't I just use the Pro Kit for a V6 f body? The extra weight of the V8 would make the front sit a little lower correct? And the Pro Kit is a progressive rate spring so there would be less chance of nailing something with the headers. I'm just throwing the idea around. Any thoughts/sugguestion/opinions? All are welcome!
Old Aug 17, 2005 | 08:18 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
IT will sit lower for sure. My buddy put a
v-8 in his 2.8 car and it has a real good stance to it.
Old Aug 18, 2005 | 08:28 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
with stock V6 springs my car had an awesome stance after the 406 swap, but my headers and y-pipe hit on big bumps. V6 springs are really soft. they work great for drag racing, but arent very good for handling
Old Aug 18, 2005 | 09:43 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: Lowering spring question. V8 car with V6 springs will it sit lower???
lol, if you seriously wanted to have that adjustibility, just go ahead and order custom springs... GM springs are dirt cheap, and you can get exactly what you want that way.
Old Aug 21, 2005 | 06:22 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
i just swapped a 357 vortec and i have my v6 springs and the stance is great. looks tough. but yea bumps are really too big of a problem and i get some good traction. hardly spin from a stop and from then on traction !!!
Old Aug 23, 2005 | 10:41 PM
sellmanb's Avatar
Car: '86 Berlinetta
While the V6 springs would work... you're asking for something that is made to lower a V6's front an inch... so whatever the V6 springs will lower a V8, it'll be by another inch... therefore I believe it will defeat the purpose?
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
