adj. spohn torque arm
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
i installed an adjustable torque arm from spohn and was wondering how do i adjust it. i have a reading of -2 on the flat part of the torque arm that bolts to the diff and i have a -2 on the driveshaft. i was told to add these fiqures up which gives me a -4. they say not to run more than -2. anyone know how i should adjust it. should i make it -1 on the diff and hope that it changes the driveshave to -1 also.
Car: 1984 ta slightly modified
Transmission: auto 350 w/reverse valve body
Axle/Gears: 410 ratio
adj tq arm
Did you get any instructions with it? They have a procedure for adjusting. If not let me know and I can send them.
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
I bought an adjustable one, [through a UK firm] and it came with nothing at all except a box.
I would be very greatful if you could send me the same details.
Thanks.
Thanks.
yes it did come with instructions but it was a little unclear on making adjustments. it said to measure the diveshaft angle and pinion angle than add them up. then they said that you shouldnt run more than -2*. when i add mine up i get a -4. question that i am having is that if i adjust it do i make the pinion at -1 hoping that the driveshaft will go to -1 also or is there another way to do it
Car: 1992 25th Anniversary Z28
Engine: 6.3L - 383
Transmission: 700R4; Vig 3200
Adjusting the torque arm will in turn adjust the angle of the DS as well, so try adjusting the TA and check to see where the DS is then....
ok i will adjust t to see where the shaft ends up. thanks guys
92rsvortec350
19
Oct 9, 2015 09:39 AM
