removing shaft from ps pump
Car: check
Engine: check
Transmission: check
To remove the shaft the pump needs to be disassembled. There is a clip on the shaft that holds it in place. Remove all of the rear cover bolts along with the pressure valve. The 'can' will then pull off of the pump body. Keep disassembling until the rear of the shaft can be accessed.
RBob.
RBob.
ambainb
Apr 25, 2016 09:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
NBrehm
Aug 25, 2015 11:49 PM
I took out the pulley and seal.. what now
