Spohn SFC's
Old Sep 6, 2005 | 11:34 PM
1BADDAM's Avatar
Car: 89 TA
Engine: 3.8 V6
Transmission: 2004R
Spohn SFC's
Spohns are supposed to be welded like this on the pass. side... correct ? (small tube piece)
Old Sep 6, 2005 | 11:35 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
no, you should of have the smaller peice branching off connected to the bar fully, its not bad, but theres room for improvement
Old Sep 7, 2005 | 10:34 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Correct. The picture below is from Spohn's website.
This picture shows a slightly different angle, http://www.spohn.net/images/PassSide8.jpg.
Old Sep 7, 2005 | 12:42 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Over built, under engineered. Why didn't they bend the cross tube down to 'T' or 'Y' into the main tube? How much more time would that have chewed up?
Old Sep 7, 2005 | 09:15 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
thats how spohn did them, thats pretty half assed imho, when i had the guy weld mine in he welded it right to the bar fully.
much stronger
Old Sep 11, 2005 | 05:54 PM
jonarotz's Avatar
Car: 91 Z28
I actually heated that bar up and bent an arc in it so it would clear the cat. and notched the end that welds to the sfc. I thought the way Spohn reccomends was kind of cheap.
Old Sep 15, 2005 | 03:14 AM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
I had similar problems, didn't like that join... so I notched the bar and dropped it about 3/4 of an inch, it has a solid weld/contact patch now.
Another thing I ran into was having to grind the crap out of the end of the driver's side bar so it would be close enough to the pinch weld. Pain in the ***, but I'm satisfied with the result.
Perhaps it was too much cost, but I learned stuff. and that's part of what this is about. And driving it. Noticed a huge difference in drivability and hooking up, especially in wet.
Old Sep 15, 2005 | 09:00 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Steve Spohn more than likely designed that tube to alleviate a stress concentration in the floor pan area. Merely welding that side tube to the main SFC does not mean you make it stronger. You could have made it worse by intensifying the stress concentration in that area above the cat. Welding that tube in the manor pictured above gives strength to that area of the sub frame and helps distribute the loading across other areas of the frame. I am pretty sure Steve knows what he is doing.
Old Sep 15, 2005 | 11:37 AM
V6#20's Avatar
Spohn made the application that way ONLY as a one fits all design because of the variety of factory and aftermarket exhaust routings. It can be install laying on top like he shipped it or if you have the fabrication skills to cut and bend it around to fit your single or dual catalytic covertor setup,etc... they you can do so to make it fit better.
Here's mine.
Old Sep 15, 2005 | 11:42 AM
waltersb's Avatar
huh? Then why does the driver's side come with a ( cut in the end of it so you can weld it straight on to the side of the tubular piece that follows the pinch weld. Is the floor pan on that side suffering less stress than the passenger side? I'm pretty sure it's welded that way to clear the Y-pipe/cats not to 'relieve some sort of stress on the floor pan' I call BS on your comment. My guess is you've never installed his SFCs
Old Sep 15, 2005 | 04:44 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
Here's mine.
THAT looks alot better to me, and is exactly how I will be doing mine. Thanks for the comments in this thread guys.
Old Sep 15, 2005 | 04:52 PM
jonarotz's Avatar
Car: 91 Z28
Thats how I did mine, but instead of cutting and rewelding it I just heated it up and bent it.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
luvofjah
Sep 26, 2015 08:28 PM
luvofjah
Sep 10, 2015 10:41 AM
