corvette wheels and lug nuts
Old Sep 11, 2005 | 09:08 PM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
does anyone knows of where to get lug nuts to fit aftermaket corvette wheels, i think there called "et" lug nuts or is it easier to put in longer studs. the stock lug nuts only grab only 3 threads on the studs right now
Old Sep 12, 2005 | 06:19 AM
ede's Avatar
ede
i think you'd want lug nuts to fit your stud more than the wheel, unless you have something like Weld uses. try a parts store, speed shop, or even a tire store.
Old Sep 12, 2005 | 02:54 PM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
well i have looked around at auto parts stores and they dont carry them or even know anything about them and i looked at a couple of tires shops and they say they cant get them in even though they know what kind of lug nuts i need
Old Sep 16, 2005 | 03:59 AM
83 Crossfire TA's Avatar
Shouldered tapered seat lugnuts are available, but I wouldn’t use them in the place of a proper length stud. Yes, the shouldered bit is threaded, but it is also quite thin and was never designed to support a load like that, they are there to center the wheel on a lug centric wheel.
Any good speed shop can get them for you, most will probably have them in stock since they are sometimes the only way to get a car home (as a temporary solution) when you get stuck messing with backspacing/spacers… I know MrLugnut and I think gorilla both make them, McGuard does not. Some of the import/tuner companies make them and all the honda’s use the same thread/pitch lugnuts, so you’ll be able to get a set there…
Drone358
Dec 10, 2015 08:16 PM
New2Chevy
Sep 28, 2015 12:35 AM
Lanz06
Sep 14, 2015 07:16 PM
fasteddi
Sep 10, 2015 09:32 AM
FormulasOnly
Sep 6, 2015 10:42 AM
