need yalls knowledge
Old Sep 11, 2005 | 10:42 PM
flaminbird 84's Avatar
Car: 1984 pontiac trans am
Transmission: 700 overdrive
i have a 84 trans an , and i just recently swapped my rear end with a 4th gen rear end, and now that i did that the rear tires stick out a lil more than they did. and i wanna look into gettin new wheels and tires and i wanna put corvette wheels on my car, if i do this will my wheels still stick out ? i want it to look i guess u would say " flushed " like they used to.. so can yall help me out with tires to go with? what yall think is a good choice
Old Sep 11, 2005 | 10:56 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
in order for you to have them flush you have to use 4th gen style wheels on your car since the back spacing on the rims is alot differnt. I would get the back spacing used for the 4th gen cars from the local GM and then look into wheels with the same back spacing.
NOTE
You will need to get spacer's for your front wheels else you will rub like a ****.
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
drumstixer
Sep 29, 2015 03:02 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
