KYB gas-a-just struts
Old Sep 27, 2005 | 06:47 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Alright, so do these exist? From what i've seen KYB only makes the gas-a-just shocks for the rears.... Anyone know why, or if this is wrong info? (or if it is true, any suggestions for a comparable front strut, like mid of the line, or cheap performance sorta thing...)
The only reason i'm disputing, is that p-s-t (www.p-s-t.com) shows a kit with 4 KYB gas-a-just shock/struts for our cars, (it's a little ambiguous, but if you scroll down you see a kit with AGX or GR2 all around, so I assumed the top kit is pure gas-a-just), AND I emailed them to double check, and haven't gotten a response...
Old Sep 28, 2005 | 11:53 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
They don't make 'em.. No gas-a-just struts in the KYB catalog..
Old Sep 28, 2005 | 10:28 PM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44 IRS, Tru Trac, 3:73 gears
They had a set in the very early 90's. There was a slot in the top that you used a key or screwdriver to selsct one of 4 settings. The adjustment fitting was made of plastic and would often break the slot. They discontinued them shortly after.
Old Sep 28, 2005 | 10:52 PM
Sonix's Avatar
Car: 1982 Trans-Am
ok, p-s-t.com got back to me, indeed, gr-2s in the front...
so gas-a-just shocks are adjustable?? nifty! I wonder why they'd only make 'em for the rear, and not the front, for a sports car, kinda sounds strange...
oh well, i'll get that set anyway.
Old Sep 28, 2005 | 10:53 PM
thirdgen88's Avatar
Car: 1995 Corvette
Gas-a-just shocks are not adjustable.. You're thinking of the AGX's.. Gas-a-just's are just monotube shocks.
Old Sep 28, 2005 | 11:15 PM
Sonix's Avatar
Car: 1982 Trans-Am
no, i'm not really thinking of anything
I just got confused, sounded like gas-a-justs were adjustable, I guess they adjust themselves...
the high end ones are adjustable eh? like koni, bilstein, AGX, etc.
Old Sep 28, 2005 | 11:28 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Are you doing any sort of racing with them? If not, you'll pay more money and probably never use the adjustments.
Most people are happy with just new struts/shocks all the way around unless you're going to hit the track every weekend.
Old Sep 28, 2005 | 11:38 PM
Sonix's Avatar
Car: 1982 Trans-Am
oh no no, no racing for me, just bombing around town...
I definately won't be spending the big $ on AGX or bilstein, I meant I was going to get GR2 fronts, and gas-a-just rears.
Old Sep 29, 2005 | 06:35 AM
IROZINCO's Avatar
gas a just
that's what I have - Gas-A-Just on rear and GR2 fronts - CAVEAT!!!! If your old shocks were REALLY worn out - be aware that this will make the car really REALLY quick - remember to adjust your driving habits after you install your gas-a-justs!
Old Sep 29, 2005 | 08:51 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I just put a new set of GR-2 / Gas-a-justs on my car. they are very decent for the money. I got my set for free so I can't complain about anything.
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
tcflint
Sep 27, 2015 05:58 PM
