Wheel question
Old Oct 3, 2005 | 06:18 PM
elky74's Avatar
Car: 82 Firebird, 71 LeMans
Engine: GMPP 350, 400 PMD
Transmission: TH-350
Wheel question
How do you measure your backspacing and bolt pattern spacing for aftermarket wheels? I want to buy a set of American Racing Torq Thrust IIs for my 'Bird, but am not sure which ones will fit. I definitely want 15x7, though.
Old Oct 4, 2005 | 01:56 AM
CrazyHawaiian's Avatar
Car: too many ...
Andris Skulte has a great FAQ on wheel backspacing and offset, includes methods to measure. Check it out at www.skulte.com
Old Oct 6, 2005 | 04:06 AM
elky74's Avatar
What size 15 inch tire looks best on a 3rd gen as far as width and profile?
Old Oct 6, 2005 | 08:11 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
First off i would go with the 8 inch wide rims if posible. 7's just arent wide enough to get any kind of traction. my 305 tbi has no problems lighting up 215/65 R15. I wish these tires looked a little wider thou. Maybe something in the 235/ 55or 45 range is what i would prefer on my 7 inchers. Also note that those tire sizes dont match factory so id run into speedo issues with them.
Old Oct 6, 2005 | 07:41 PM
92camarors5spd's Avatar
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
you measure backspacing by laying the rim face down. getting a measuring stick and a straight edge. lay the straight edge on the back rim lip. and take your ruler and place it in the center and measure your backspacing. and you measure your bolt pattern by measuring your stud lenth in a star pattern(if that makes sense)the same way you tighten down lug nuts.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
