quick question on springs and shocks
Old Oct 3, 2005 | 07:28 PM
age's Avatar
age
Car: 1992 Z28 1LE
just a quickie guys..
but what's a good way to test if shocks/struts are blown, and also, how would I know if I've got sagging springs?
I just installed a set of lowering springs and shocks (OEM) that are USED from a friend, and the pass REAR is sitting a bit higher than the driver's rear tire. I took it for a test drive to seat the suspension, but no luck.. thanks!
Old Oct 4, 2005 | 02:30 AM
CrazyHawaiian's Avatar
Car: too many ...
Measure the car on a flat surface, if the drivers and pass side of either the front or rear are not even then there is a problem with the springs. You can re-install the spring and ensure it is indexed properly. If you still have the problem, then the springs are probably worn (assuming everything else is the same, example both sides have isolators). Unfortunately for the average enthusiast, we dont have the tools to really verify if a spring or strut or shock is worn, we have to use these sort of ghetto tests. Shops that make this stuff have machines to test them. Anyway, for the struts/shocks you can tell if they're worn if the body movement is excessive, car is bouncing up and down when you go over speedbumps, or if the front or rear bottoms out. Body movement should be firm and nothing should bottom out.
customblackbird
Aug 15, 2021 10:16 PM
crazynights
Aug 21, 2015 06:53 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
