Dropzone Springs, Will These Struts Work?
Old Oct 3, 2005 | 09:29 PM
KBeez's Avatar
Car: 88 Camaro S/C
Transmission: 700-R4
Hey I just got dropzone springs and I guess I'll change the struts too while I'm down there.
http://cgi.ebay.com/ebaymotors/ST-SH...spagenameZWDVW
I'm trying to fix up the car, but it's still a daily driver, and I'm only 19 at that, but will they work alright?
They'll be paired up with a 4th gen disc rear end, the dropzone springs, tubular lca's, and spohn sfc's.
Old Oct 4, 2005 | 02:39 AM
CrazyHawaiian's Avatar
Car: too many ...
Yeah they'll work. I'm not sure if they are a good match, but they'll work together. The hard thing about working with these cheaper parts is the manufacturers wont release the actual specs of the part. So you never really know what its gonna be like until you have it all installed. Dropzone dosnt release spring rates and ST dosnt release compression/rebound rates so its hard to know. The ST add says it'll work for lowered cars, so you should be alright. One thing will be for sure, it'll be better then blown OEM stuff.
Just an opinion but I'd recommend you do the LCA's later. I would ensure all bushings are good, and if so put that $$ into better Dampeners and/or Springs. If not get the bushings in good working order.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
TheExaminer
Aug 25, 2015 07:34 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
1992 Trans Am
Aug 9, 2015 04:32 PM
