Bump stop relocation / Spohn A-arms
Car: 1983 Z28
Engine: GMPP 350, 92 TPI
Axle/Gears: Auburn gear posi, 3.08
Bump stop relocation? / Spohn A-arms
I'm going to install my Spohn performance tubular front a-arms with spring boxes on Monday. Where should I mount the bumpstops on the car? Anyone done this yet? A pic perhaps?
Thanks.
Thanks.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Bump stop relocation? / Spohn A-arms
Thanks.
Thanks.
I'm not sure which ones ground control sells, but pretty much the best stuff out there along those lines are the Koni sylasto (sp?) shaft bump stops...
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
they're similar, the only pic of the koni's I can find is in this PDF:
http://maximummotorsports.com/instructions/MMSM-5.pdf
Car: 1983 Z28
Thanks guys, very helpful. I have even been planning on putting Konis on my car. The Ground control stuff looks good for now though. Whatever I can get my hands on most likely.
Car: '89 Black IROC 'vert
Transmission: 700-R4
Axle/Gears: 2.73 posi
I'm in the process of installing the Spohn tubular A-arms and new struts/springs myself, and was wondering if you guys had any reccomendations on the firmness/size of bumpstop to order? The struts & springs are Tokico HPs.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I went with the ground control ones and have had no problems. I pulled my receipt for a part # but it just said "bumpstop". Make sure they give you ones for a 3rd gen and not a 4th (they are different, won't work, and I have a free set sitting in my spare parts pile)!!
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Thanks.do you know why they have a 10-14mm set & a 19-24mm set(s).Is that refering to height or ?.What do yours look like(shaped).
Originally Posted by 84 1LE
Great,those are the ones i was looking to get,Thanks for the help.
Car: 1983 Z28
Energy suspension
9.9101 All purpose bump stop for control arms, traction bars & leaf springs. Designed to be easily trimmed. 2 1/8" tall, 2" dia. 2 per set
Actually these are what I used, I trimmed the first three layers off and mounted them to the frame.
