Pulling to one side
Old Oct 12, 2005 | 09:11 AM
Lampropeltis's Avatar
Car: '89 Flame red metallic GTA!!
Pulling to one side
Just put new ball joints, new front tires, had them balanced and had a wheel alignment done. The car drove perfect for about 10 days, now it is beginning to pull slightly to the left. I thought having the wheels aligned would cure the pull to one side. Should it? Or is there something I have overlooked that would cause it to do that? I know that I have to replace the front struts, would bad struts cause a car to go out of alignment already? Or is it possible that the place I took it to did a ****ty job of aligning the car?
Thanks for any info.
Old Oct 12, 2005 | 09:20 AM
FORMULA355TPI's Avatar
Car: 88 FORMULA / 88 IROC
Engine: 355 / 355
Transmission: T5 / TH400
Axle/Gears: 10 Bolt-3.73 / 9"-3.90
It is possible one of your strut plates could have been left loose and moved. Most alignment shops will recheck your car within a week or so maybe you should give the shop a call..
Old Oct 12, 2005 | 09:30 AM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
Just check the tyre pressures as well, its a known fact alloys can lose air fast if theres a bad seal, low pressure can cause a pull.
Old Oct 12, 2005 | 01:53 PM
llvll4l2c91350's Avatar
if they are not directional, rotate the front only. left to right, right to left.
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Bert87
Aug 23, 2015 03:50 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Street Lethal
Aug 14, 2015 08:25 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
