bottoming out
Old Oct 13, 2005 | 11:52 AM
Ziggster's Avatar
Car: 1988 Camaro
Engine: 173 CI
Axle/Gears: open 3.42's
bottoming out
so my car bottoms out in the back from time to time, is this just cause the shocks need replaced or could it be weak rear springs. I have had many other 3rd gens and never had this problem so.....
Old Oct 13, 2005 | 01:04 PM
wellington's Avatar
Car: 83 firebucket
Engine: less then a geo
Transmission: 5speed crap box
its springs, just replace them and check all the bushings while your at it.
Old Oct 13, 2005 | 04:09 PM
Ziggster's Avatar
Car: 1988 Camaro
Engine: 173 CI
its just a six should i just get stock replacement jobs from a perts store or....
Old Oct 13, 2005 | 07:13 PM
CrazyHawaiian's Avatar
Car: too many ...
Too much travel causing you to bottom out is usually the result of worn dampeners, so in this case the rear shocks. Its also possible its the spring, but only if its an aftermarket spring that has a low ride height and rates that are too soft for the resulting ride height.
Old Oct 14, 2005 | 02:11 AM
Ziggster's Avatar
Car: 1988 Camaro
Engine: 173 CI
looks like most everything is stock and its only a 6 so i doubt the previous owner would spent to much time on suspension mods. I will go with the shocks first, replacement springs for it are only like 50 bucks so maybe i should replace them anyway. Thanks for the help guys
3rd gen money
Oct 11, 2019 09:57 PM
MrPackstin
Oct 25, 2017 08:09 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Numbah-1
Oct 2, 2015 08:27 AM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
